5 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.77374
Background
The Craftsman Trimmer Model 917.773740 is a gas-powered string trimmer. It's designed with a 22-inch cutting width and employs a Briggs & Stratton 126T02-1064-B1 engine. This engine has a displacement of 126 cc and can produce 2.5 HP. The fuel capacity is 1.6 quarts of unleaded regular gasoline with a minimum octane rating of 87. The oil capacity is 20 oz of SAE 30 for temperatures above 32°F and SAE 5W-30 for temperatures below 32°F. The trimmer line has a diameter of 0.155 inches and a length of 18.75 inches. The total weight of the trimmer is approximately 20 lbs.
The Craftsman Trimmer Model 917.773740 offers an easy-starting Briggs & Stratton engine and an automatic trimmer head feed. It also includes an adjustable assist handle with multiple positions and a debris shield to protect users from flying debris. The quick height adjust lever provides 6 position options and an operator presence control bar. The trimmer requires regular maintenance such as checking the engine oil level before each use, changing the engine oil after the first 5-8 hours of use and then every 25 hours or season, cleaning the air filter regularly and replacing it once per season, inspecting the trimmer head and lines and replacing worn lines, cleaning the underside of the trimmer after each use to remove grass buildup, and cleaning the engine to prevent overheating.
Technical Specifications
- Model Number: 917.773740
- Product Type: Trimmer
- Engine: Briggs & Stratton 126T02-1064-B1 4-cycle engine
- Displacement: 126 cc
- Power: 2.5 HP
- Fuel capacity: 1.6 quarts unleaded regular gasoline (87 octane minimum)
- Oil capacity: 20 oz SAE 30 above 32°F, SAE 5W-30 below 32°F
- Cutting width: 22 inches
- Trimmer line diameter: 0.155 inches
- Trimmer line length: 18.75 inches
- Weight: approx. 20 lbs
Warranty
The Craftsman Trimmer Model 917.773740 comes with a 2-year limited warranty. This warranty covers any defects in materials and workmanship from the date of purchase, provided the product is used for residential purposes and maintained properly. If the trimmer is used for commercial or rental purposes, the warranty coverage is for 90 days from the date of purchase. The warranty does not extend to normal wear parts or cases of improper use or abuse. To claim the warranty, it is typically required to provide proof of purchase and follow the manufacturer's instructions, which may include contacting customer service or submitting a claim form.
