2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
917.773704
Background
The Craftsman Trimmer 917.773704 is a gas-powered device intended for the trimming of lawns and control of weeds in residential areas. The trimmer is equipped with a Briggs & Stratton 122H02-0110-B1 4-stroke overhead valve engine, which has a horsepower of 6.0. It has a cutting width of 22 inches. The device also features a foldable upper handle with adjustable heights and 9-inch plastic wheels for easy maneuverability. The trimmer uses a cutting line with a diameter of 0.155 inch and includes two 18.75 inch pre-cut lines.
The trimmer is self-propelled and designed to trim grass and weeds around residential properties. It operates using a bump-head style trimmer head that allows new line to be advanced by tapping the head on the ground. The trimmer has height-adjustable wheels for smooth operation over uneven terrain. The main handle and an adjustable assist handle provide comfortable control of the trimmer. The device comes ready to use with two 18.75 inch 0.155 inch diameter pre-cut trimmer lines installed. It also has features like a debris shield, chassis cover, and belt keepers to protect internal components.
Technical Specifications
- Engine: Briggs & Stratton 122H02-0110-B1, 6.0 HP, 4-stroke OHV
- Displacement: 140cc
- Fuel capacity: 1.6 quarts
- Fuel type: Unleaded regular gasoline, 87 octane minimum
- Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
- Oil capacity: 20 oz
- Starting method: Recoil start
- Cutting width: 22 inches
- Cutting height: 1.5 - 3 inches adjustable
- Handle: Foldable upper handle with adjustable heights
- Wheels: 9 inch plastic wheels
- Cutting line: 0.155 inch diameter, comes with two 18.75 inch pre-cut lines
- Weight: 73 lbs
Warranty
The Craftsman Trimmer 917.773704 is offered with a 2-year limited warranty. This warranty covers any defects in materials and workmanship from the date of purchase. However, it is important to note that normal wear items like trimmer line, belts, and air filters are not included in this warranty. Additionally, the warranty would be voided if the product is used for commercial purposes or if it is not maintained properly. To claim the warranty, refer to the instructions provided in the product's manual or contact the manufacturer directly.
