3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79921
Background
The Craftsman Trimmer 358.799211 is a gas-powered string trimmer designed for yard maintenance. The trimmer is powered by a 21cc two-cycle engine and is capable of a 15-inch cutting path. It features an engine displacement of 21cc and operates at 8000 RPM. The ignition is solid state with a non-adjustable spark advance. The carburetor is a diaphragm type with an adjustable fuel jet and the muffler has a temperature limiting feature.
Additional components of the Craftsman Trimmer 358.799211 include an auto-rewind starter and a fuel tank with a capacity of 140cc. The spark plug is a Champion CJ14 with a 0.025" gap, and the module air gap measures between 0.010" and 0.014". The trimmer operates on a gasoline/oil mix at a 40:1 ratio. The cutting line is made of 0.080" diameter nylon. Notable features of the trimmer include a 15" cutting swath, a semi-automatic trimmer head that feeds fresh line without bumping, and an adjustable assist handle for user comfort and control. Despite its capabilities, the trimmer maintains a lightweight design, weighing under 9 pounds.
Technical Specifications
- Model Number: 358.799211
- Product Type: Gas-powered string trimmer
- Engine: 21cc two-cycle, air cooled
- Engine Displacement: 21cc
- Operating RPM: 8000
- Ignition: Solid state with non-adjustable spark advance
- Carburetor: Diaphragm type with adjustable fuel jet
- Starter: Auto rewind
- Muffler: Temperature limiting
- Cutting Path: 15 inches
- Fuel Tank Capacity: 140cc
- Spark Plug: Champion CJ14, 0.025" gap
- Module Air Gap: 0.010" to 0.014"
- Lubrication: Gasoline/oil mix (40:1 ratio)
- Cutting Line: 0.080" diameter nylon
- Weight: Under 9 lbs
- Additional Features: Semi-automatic trimmer head, adjustable assist handle
Warranty
The Craftsman Trimmer 358.799211 comes with a 2-year limited warranty provided through Sears retailers. This warranty covers defects in materials and workmanship. However, please note that normal wear parts such as the trimmer line, spark plugs, and air filters are not included in the warranty coverage. To claim the warranty, you would need to approach a Sears retailer and provide necessary details, such as proof of purchase.
