2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
358.79912
Background
The Craftsman Trimmer 358.799120 is a string trimmer fueled by a mixture of gasoline and oil. Manufactured by Poulan/Weedeater for Sears, it was introduced to the market in 1993. The trimmer is equipped with a 26cc 2-cycle engine and is designed to cut a swath of 16 inches. The fuel mix recommended for this model is 40:1. As a string trimmer, this tool is primarily used for cutting grass and weeds, especially in areas that are challenging to reach with a standard lawnmower, such as along fences or around trees.
The Craftsman Trimmer 358.799120 incorporates a dual line bump head, which simplifies the process of line replacement. It is built with an adjustable loop handle for user comfort and weighs approximately 10 pounds. This tool requires regular maintenance, including cleaning the air filter and replacing the spark plug and trimmer line as necessary. The trimmer's fuel and oil tank are designed for easy access, simplifying the process of refueling and mixing oil.
Technical Specifications
- Model Number: 358.799120
- Product Type: Gasoline-powered string trimmer
- Engine: 25cc 2-cycle engine
- Starting Mechanism: Easy pull starting
- Cutting Mechanism: Dual line bump head for quick line replacement
- Cutting Width: 18 inches
- Handle: Loop handle and assist handle
- Weight: Approx. 10 lbs
- Fuel Requirements: 50:1 gasoline and 2-cycle oil mix
- Maintenance Required: Cleaning the air filter, replacing the spark plug annually, and replacing the trimmer line as needed
- Safety Features: Spring-assisted starting system to reduce kickback when pulling the starter cord, stop switch to instantly stop the trimmer.
Warranty
The Craftsman Trimmer 358.799120 comes with a 2-year limited warranty. This warranty is applicable to any defects found in the materials and workmanship of the product. However, it's crucial to note that the warranty does not provide coverage for any damages resulting from misuse or accidents. To claim the warranty, you will need to present proof of purchase.
