2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.797161
Background
The Craftsman Trimmer 358.797161 is a gas-powered string trimmer made by Poulan/WeedEater for Sears. This trimmer utilizes a 32cc 2-cycle air-cooled engine that has a maximum power of 7500 rpm idle ranging between 2500-3200 rpm. The engine's ignition relies on a solid state with adjustable fuel mixture jets while the carburetor is of the diaphragm type, suitable for all positions. The fuel capacity is 17 fl oz and the recommended spark plug is a Champion RCJ7Y with a gap of 0.025".
The Craftsman Trimmer 358.797161 has several features including an automatic line feed that allows the trimmer line to advance on its own as it wears down during use. It also has a centrifugal clutch that engages the trimmer head when the engine reaches a certain rpm. For comfort during extended use, it has an anti-vibration cushioned assist handle. The trimmer is also relatively lightweight, with the powerhead weighing in at 8.7 lbs. The trimmer, equipped with an 18" cutting path, is ideal for residential lawn trimming and weed removal.
Technical Specifications
- Engine: 32cc 2-cycle air cooled
- Max Power: 7500 rpm idle - 2500-3200 rpm
- Ignition: Solid state with adjustable fuel mixture jets
- Carburetor: Diaphragm type, all position
- Fuel Capacity: 17 fl oz
- Spark Plug: Champion RCJ7Y (Gap 0.025")
- Automatic line feed: Yes
- Centrifugal clutch: Yes
- Anti-vibration cushioned assist handle: Yes
- Weight: 8.7 lbs powerhead only
- Cutting Path: 18"
Warranty
The Craftsman Trimmer 358.797161 comes with a limited lifetime warranty provided by Sears. This warranty covers any defects that may occur due to materials and workmanship. However, it's important to note that wear items like the trimmer line, spark plugs, and air filters are not included in the warranty coverage. Moreover, the warranty is valid only if the trimmer is used for residential purposes; commercial use would void the warranty. To claim the warranty, refer to the terms and conditions specified in the product's manual or contact Sears' customer service for further assistance.
