2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.7966
Background
The Craftsman 358.796600 Trimmer is a gasoline-powered line trimmer with a 25cc, 1.5 cu. in. 2-cycle engine. Designed for residential use, this machine is capable of regular trimming, edging, and light brushcutting. It utilizes a 40:1 gas/oil mix, has a fuel tank capacity of 14 fl. oz., and a cutting swath of 17 inches. Its line size is 0.095 in., and it features a straight shaft. The trimmer weighs 11 lbs.
The Craftsman 358.796600 Trimmer comes equipped with an ON/OFF switch, a primer bulb and start lever for easy starting, an adjustable assist handle, and a debris shield with a line limiter blade. It also includes a coupler for installing optional attachments such as an edger, cultivator, blower, brushcutter, and pruner. The engine is certified to comply with EPA Phase 1 and Phase 2 emissions regulations, as well as California emissions regulations. Regular maintenance, including checking for loose fasteners, worn parts, cleaning the unit, and replacing the spark plug, is recommended.
Technical Specifications
- Engine: 25cc, 1.5 cu. in. 2-cycle gasoline
- Fuel ratio: 40:1 gas/oil mix (3.2 oz oil per 1 gallon gas)
- Fuel tank capacity: 14 fl. oz. (0.42 L)
- Cutting swath: 17 in. (43 cm)
- Line size: 0.095 in. (2.4 mm)
- Shaft: Straight
- Weight: 11 lbs (5 kg)
Warranty
The Craftsman Trimmer 358.796600 comes with a one-year warranty against defects in materials or workmanship, as long as the product is maintained according to the instruction manual. The warranty does cover all parts of the trimmer, but it excludes expendable parts like the nylon line, spark plug, and air filter. For commercial use, the warranty is valid for 90 days and for rental use, the validity is shortened to 30 days from the date of purchase. To claim the warranty, please refer to the instruction manual or contact Craftsman customer service for further assistance.
