3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79628, 358.796280
Background
The Craftsman Trimmer 358.796280 is a gas-powered weed trimmer, known for its 25cc, 1.5 cu. in. 2-cycle gas-powered engine. It is designed to have a 17-inch cutting path and uses a 0.080 inch diameter trimmer line. This product is typically used in residential settings for yard trimming and edging tasks. It is noted for its curved shaft design, which allows for easy maneuverability when trimming around fences, gardens, and other landscaping features.
The trimmer's head is designed to advance the trimmer line automatically when the head contacts the ground during operation. It comes equipped with an assist handle and a debris shield. The product is fueled by a 40:1 gas to oil mix. However, the fuel capacity, the weight of the trimmer, and the engine's horsepower remain unspecified. The trimmer also includes a variety of parts such as the trimmer unit itself, a debris shield, a wing nut for the shield, a container of oil, and an extra spool of 0.080" line.
Technical Specifications
- Model Number: 358.796280
- Product Type: Trimmer
- Engine: 25cc, 1.5 cu. in., 2-cycle gas-powered
- Cutting path: 17 inches
- Line diameter: 0.080 inches
- Fuel type: 40:1 gas to oil mix
Warranty
The Craftsman Trimmer 358.796280 comes with a one-year full warranty that covers any defects in materials and workmanship. However, expendable parts like the trimmer line, spark plug, and air filter are not included in this warranty. In the case of commercial use, the warranty is valid for 90 days from the date of purchase. If the product is used for rental purposes, the warranty extends for 30 days from the purchase date. Furthermore, the emissions control system, which incorporates the carburetor and ignition system, is warranted for two years. To make a warranty claim, you should contact Sears Parts and Service.
