3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79627
Background
The Craftsman Trimmer 358.796270 is a string trimmer designed for trimming grass and light weeds. It is gasoline-powered and utilizes a 24cc 2-cycle engine. Its cutting path is 17 inches wide, and it makes use of a 40:1 gas/oil mix as fuel. The trimmer is equipped with a Champion RCJ-8Y spark plug and employs a 0.080 inches (2mm) round line diameter.
The Craftsman Trimmer 358.796270 features a curved shaft design and an adjustable assist handle, allowing it to be configured for both trimming and edging tasks. The incorporated bump head string advance system enables fresh trimmer line advancement without the need for tapping. Regular maintenance is required for optimal performance, which includes cleaning the air filter every 5 hours of use and replacing the spark plug annually. It is also necessary to check for loose fasteners and damaged or worn parts, and to keep the unit clean.
Technical Specifications
- Model Number: 358.796270
- Product Type: String Trimmer
- Manufacturer: Sears
- Power Source: Gasoline
- Engine: 24cc, 1.46 cu.in., 2-cycle
- Cutting Path: 17 inches
- Fuel Mix Ratio: 40:1 gas/oil mix
- Spark Plug: Champion RCJ-8Y
- Line Diameter: 0.080 inches (2mm) round
- Design: Curved shaft
- Features: Bump head string advance system, adjustable assist handle, can be configured for trimming or edging tasks
Warranty
The Craftsman Trimmer 358.796270 comes with a full 1 year warranty that covers defects in materials and workmanship. However, it is important to note that this warranty does not cover expendable parts such as the trimmer line, spark plug, and air filter. In case the product is utilized for commercial purposes, the warranty period is reduced to 90 days. To claim the warranty, it is best advised to get in touch with the manufacturer, Sears, and provide necessary details like product model number, date of purchase, and describe the issue at hand.
