2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.7958
Background
The Craftsman Trimmer 358.795800 is a trimmer that utilizes a 32cc, 1.9 cu. in. 2-cycle gas engine. Manufactured by Sears, this trimmer was introduced to the market in 2006. The product offers a rear motor design and straight, locking shaft, expanding its range of trimming versatility. It comes equipped with both a 4-point and 8-point weed blade. Its design includes an ON/OFF switch for engine operation, a primer bulb for start-up, and a choke lever for cold starts. An additional feature is the clutch system that ensures smooth operation.
The Craftsman Trimmer 358.795800 has a fuel capacity of 10 fl. oz. (0.3 L) and offers a cutting swath of 17 in. (43 cm). The trimmer line has a diameter of 0.095 in. (2.4 mm), with the trimmer head speed reaching up to 7800 RPM and the weed blade speed reaching up to 11,500 RPM. The weed blade arbor size is 0.325 in. (8.3 mm). In terms of dimensions, the trimmer has a length of 71 in. (180 cm) and a dry weight of 12 lbs. (5.5 kg). It requires a mixture of gasoline and 2-cycle synthetic oil at a ratio of 40:1 for operation.
Technical Specifications
- Model Number: 358.795800
- Manufacturer: Sears
- Product Type: Trimmer
- Release Year: 2006
- Engine Type: 32cc, 1.9 cu. in., 2-cycle with reciprocating starter
- Fuel Capacity: 10 fl. oz. (0.3 L)
- Cutting Swath: 17 in. (43 cm)
- Trimmer Line Diameter: 0.095 in. (2.4 mm)
- Trimmer Head Speed: 7800 RPM
- Weed Blade Speed: 11,500 RPM
- Weed Blade Arbor Size: 0.325 in. (8.3 mm)
- Length: 71 in. (180 cm)
- Weight: 12 lbs. (5.5 kg)
- Operation: Requires mixing gasoline and 2-cycle synthetic oil at a 40:1 ratio
- Cutting Method: Can be configured with a trimmer head for grass and weeds or a metal weed blade for cutting grass, weeds and brush up to 1/2 inch diameter
- Additional Features: Includes shoulder strap and handlebar for comfort and control, ON/OFF switch, primer bulb for easy starts, choke lever for cold starts, clutch system for smooth operation
Warranty
The Craftsman Trimmer 358.795800 comes with a 2-year full warranty that covers defects in material and workmanship. However, please note that certain parts, such as the cutting line, spark plug, and air filter, are considered expendable and are therefore not included in the warranty coverage. If you discover a defect in the trimmer during the warranty period, you will need to contact the manufacturer or your point of purchase to make a claim. Please ensure to keep your proof of purchase, as it may be required during the claim process.
