2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79556
Background
The Craftsman Trimmer 358.795560 is a gasoline-powered tool used for landscaping tasks. Manufactured by Craftsman, this model is typically utilized for light-duty tasks including edging, trimming, and clearing overgrown areas. The gasoline engine that powers the trimmer is a 32cc/1.9 cu.in. 2-cycle model, and the trimmer itself uses a 40:1 gasoline/oil mixture for fuel.
The 358.795560 model features a curved shaft, which offers improved maneuverability and ease of use when trimming. It also has a rewind starter for initiating the 2-cycle engine. The trimmer head uses a nylon cutting line that spins at 7500 RPM, allowing it to effectively cut through grass and other light vegetation. The trimmer is also equipped with a debris shield, line limiter blade, and a vibration damping system. The unit's fuel tank can hold up to 21 oz (0.625 L) of fuel, and it has a cutting swath of 17 in (43 cm). The diameter of the line is 0.080 in (2 mm), and the overall weight of the unit is 10 lbs (4.5 kg).
Technical Specifications
- Engine: 32cc/1.9 cu.in. 2-cycle gasoline engine
- Fuel mixture: 40:1 gasoline/oil
- Fuel tank capacity: 21 oz (0.625 L)
- Cutting swath: 17 in (43 cm)
- Line diameter: 0.080 in (2 mm)
- Handle: Assist handle and full wrap around handle
- Weight: 10 lbs (4.5 kg)
Warranty
The Craftsman Trimmer 358.795560 comes with a 2-year limited warranty provided by Craftsman. This warranty covers any defects in the materials or workmanship of the tool. However, it is important to note that parts that are subject to normal wear and tear such as the trimmer line, spark plug, and air filter are not covered under this warranty. If the product is used for commercial or rental purposes, the warranty period is reduced to 90 days and 30 days respectively. To claim the warranty, you can contact Craftsman or any authorized service center.
