3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.795551
Background
The Craftsman Trimmer 358.795551 is a gas-powered gardening tool, specifically designed for cutting and trimming grass, weeds, and overgrowth. It operates on a 25cc, 1.5 cubic inch 2-cycle gas engine and features a 17-inch cutting path. The trimmer line measures 0.080 inches in diameter, and the trimmer head is designed to rotate at 6500 RPM. The fuel for this trimmer requires a 40:1 gas to oil ratio, and the spark plug, a Champion RCJ-GY, should be replaced yearly.
This trimmer is equipped with an automatic line advance trimmer head, which feeds the trimmer line and allows for no-bump line replenishment. For the operator's comfort during use, the trimmer includes an assist handle and a shoulder strap. The overall weight of the Craftsman Trimmer 358.795551 is approximately 10 pounds. The engine is pre-tuned at the factory with the carburetor set for optimal performance, but may require adjustment under certain conditions.
Technical Specifications
- Engine: 25cc, 1.5 cubic inch, 2-cycle gas powered
- Cutting Path: 17 inches
- Trimmer Line: 0.080 inch diameter
- Fuel Ratio: 40:1 gas to oil ratio (3.2 oz oil per 1 gallon gas)
- Spark Plug: Champion RCJ-GY
- Trimmer Head Rotation Speed: 6500 RPM
- Weight: Approximately 10 pounds
Warranty
The Craftsman Trimmer 358.795551 comes with a full 1-year warranty that covers defects in materials or workmanship, provided the recommended engine maintenance and lubrication are performed. The warranty guarantees repair or replacement of defective warranted parts. However, it is important to note that nylon trimmer line, spark plug, and air filter are expendable parts and are consequently not covered by the warranty. If the trimmer is used for commercial or rental purposes, the warranty coverage period is 90 days from the date of purchase. In order to claim the warranty, return the trimmer to the nearest Sears store or service center.
