2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.795542
Background
The Craftsman Trimmer 358.795542 is a gas-powered weed trimmer, produced by Sears, Roebuck and Co. The trimmer is fitted with a 25cc/1.5 cu.in. 2-cycle engine and uses a 0.080-inch diameter nylon line for trimming. The line is delivered via a bump feed system, which allows for the advancement of new line with a simple tap on the ground. The cutting path of the trimmer is 17 inches, allowing for efficient trimming over larger areas.
This model is primarily designed for occasional use in yard and landscaping tasks. It is equipped with a straight tube for regular trimming and an adjustable tube for edging tasks. An assist handle and a covered trigger area are incorporated into the design to ensure comfort and control during operation. The trimmer is relatively lightweight, weighing approximately 10 lbs, which aids in maneuverability.
Technical Specifications
- Model Number: 358.795542
- Product Type: Trimmer
- Engine: 25cc/1.5 cu.in. 2-cycle
- Cutting Path: 17 inches
- Line Diameter: 0.080 inches
- Fuel Mix Ratio: 40:1 (3.2 oz oil per 1 gallon gas)
- Starter: Recoil
- Weight: Approximately 10 lbs
Warranty
The Craftsman Trimmer 358.795542 comes with a full 1-year warranty when used for household purposes, covering any defects in materials or workmanship from the date of purchase. This warranty, however, does not cover normal expendable parts like trimmer line, spark plugs, and air filters that wear out with use. If the trimmer is used commercially, the warranty period reduces to 90 days, and for rental use, it lasts for 30 days. To claim this warranty, the trimmer must be returned to the nearest Sears store or service center. It is important to note that this warranty offers specific legal rights, and other rights may vary depending on location.
