1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
358.79535
Background
The Craftsman Trimmer 358.795350 is a gas-powered string trimmer, created by Craftsman. Information about this specific model's technical specifications and detailed product features is not available due to lack of context. However, based on common features of Craftsman trimmers, it can be inferred that this model is used for trimming grass and light vegetation in areas that are difficult to access with a standard lawn mower, such as around fences and landscaping features. The trimmer likely has a start ignition system, an adjustable assist handle for control, and the ability to accept different trimmer head attachments for various tasks.
Most Craftsman trimmers are powered by small gas engines that rotate a trimmer head. This head holds a spool of nylon cutting line, which spins at high speeds to cut through grass and weeds. As the line wears down during use, the trimmer head allows new line to be fed out. The Craftsman Trimmer 358.795350 model is likely to have a gas engine displacement of 25cc or 30cc, and its weight is probably in the range of 10 to 15 lbs. This trimmer model, as one of the Craftsman products, is likely to serve homeowners for several years if maintained properly.
Technical Specifications
- Product Type: Gas-powered string trimmer
- Manufacturer: Craftsman
- Function: Designed for trimming grass and light vegetation around fences, landscaping features and other tight spaces.
- Ignition System: Likely features an easy-start for quick starts
- Handle: Adjustable assist handle for comfort and control
- Attachments: Can accept different trimmer head attachments for versatility
- Power Source: Powered by a small gas engine that drives a rotating trimmer head
- Trimmer Head: Contains a spool of nylon cutting line that spins at high speeds to cut through grass and weeds. Allows new line to be fed out as it wears down during use.
- Engine Displacement: Likely has a 25cc or 30cc gas engine displacement
- Weight: Likely weighs around 10 to 15 lbs.
Warranty
The Craftsman Trimmer 358.795350, as a Craftsman product, comes with a standard 2-year manufacturer's warranty. This warranty covers defects in materials and workmanship, offering repair or replacement of defective parts free of charge during the warranty period. The gas engine of the trimmer may also be under a separate warranty offered by the engine maker. To claim the warranty, it would generally involve reaching out to Craftsman or the engine manufacturer with proof of purchase and details of the issue.
