3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79532
Background
The Craftsman Trimmer 358.795320 is a gas-powered gardening tool, designed for residential yard work. Its primary function is to trim grass and small, woody plants. The trimmer is equipped with a 24cc 2-cycle engine and uses a 17-inch cutting path. The tool utilizes a 0.080 inch diameter nylon cutting line for trimming. The fuel for this trimmer requires a specific ratio of 40:1 gas to oil mix.
This trimmer is designed with a straight shaft, useful for trimming under obstacles and reaching difficult areas. It is equipped to advance the nylon cutting line each time the head is tapped on the ground. The length of the line is controlled by a limiter blade on the protective shield, and the tool is designed for effective cutting at less than full throttle. The trimmer requires regular maintenance including air filter cleaning and spark plug replacement. Off-season storage preparations, such as draining fuel and removing the spark plug, are needed to prevent engine damage.
Technical Specifications
- Model Number: 358.795320
- Product Type: Trimmer
- Engine: 24cc 2-cycle
- Cutting Path: 17 inches
- Fuel Type: 40:1 gas to oil mix
- Line Diameter: 0.080 inches
Warranty
The Craftsman Trimmer 358.795320 comes with a one-year limited warranty that covers defects in materials and workmanship focused on the engine, shaft, and trimmer head parts. However, expendable parts such as the nylon cutting line, spark plug, or air filter are not included in the coverage. For those using the trimmer for commercial purposes, the warranty period is shortened to 90 days. In order to claim the warranty, it's crucial to retain your purchase receipt and contact the manufacturer or authorized dealer in case of any defects or malfunctions during the warranty period.
