3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79516
Background
The Craftsman Trimmer 358.795160 is a gasoline-powered line trimmer. The engine is a 32cc 2-cycle air-cooled type, suitable for trimming, edging, and light duty cutting tasks. This device is primarily intended for intermittent residential use.
The Craftsman 358.795160 line trimmer possesses a straight shaft design, cushioned loop handle and an in-line throttle trigger, providing ease in movement. It utilizes a semi-automatic bump feed trimmer head that advances fresh trimmer line with a simple ground tap. The trimmer head can accommodate up to 20 feet of 0.080 inch diameter monofilament line. The fuel capacity of the engine is 14 oz (0.4 L) and it requires a 40:1 fuel mixture of unleaded gasoline and 2-cycle engine oil for operation.
Technical Specifications
- Engine: 32cc 2-cycle air-cooled engine
- Fuel capacity: 14 oz (0.4 L)
- Cutting swath: 17 in (43 cm)
- Line diameter: 0.080 in (2.0 mm)
- Weight: 10.8 lbs (4.9 kg)
- Design: Straight shaft with cushioned loop handle and in-line throttle trigger
- Trimmer head: Semi-automatic bump feed
- Line length: Up to 20 feet
- Fuel mixture: 40:1 ratio of unleaded gasoline and 2-cycle engine oil
Warranty
The Craftsman Trimmer 358.795160 is equipped with a 2-year consumer warranty from the date of purchase. This warranty covers any defects in materials or workmanship but does not extend to expendable parts like the trimmer line, spark plug, and air filter. It should be noted that commercial and rental use of the product reduces the warranty period to 90 days and 30 days respectively. To maintain the validity of the warranty, routine maintenance procedures, as described in the instruction manual, must be performed. In case of any issues, warranty service can be accessed by contacting Sears retail stores and service centers. Additionally, the engine warranty is also valid for 2 years for consumer use and covers components like the carburetor, ignition module, and spark plug. Emission related warranty service can also be availed at Sears service centers.
