3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79515
Background
The Craftsman Trimmer 358.795150 is a line trimmer that operates on a gas-powered engine. It was manufactured by Sears, a well-known retailer. The engine of the trimmer is of a 2-cycle type and has a 25cc/1.5 cu. in. capacity. The trimmer cuts with a 17-inch path and uses a 0.080-inch line.
The Craftsman 358.795150 is intended for use by homeowners. It utilizes a curved shaft and operates on gasoline. The trimmer requires a fuel mix of 40:1 gasoline to oil ratio, with 3.2 oz of oil per gallon of gasoline. The trimmer head uses a pre-wound spool of 0.080-inch diameter nylon cutting line. The cutting line advances when the trimmer is tapped on the ground. Other features include an assist handle and a debris shield.
Technical Specifications
- Engine Type: 25cc/1.5 cu. in. 2-cycle
- Cutting Path Width: 17 inches
- Line Diameter: 0.080 inches
- Fuel Mix: 40:1 gasoline to oil ratio (3.2 oz oil per gallon gasoline)
Warranty
The Craftsman Trimmer 358.795150 comes with a full one-year warranty that covers any defects in materials or workmanship. For those who use the product commercially, the warranty period is reduced to 90 days. If the trimmer is used for rental purposes, the warranty lasts for 30 days. In addition to this, the emission control system of the engine has a separate warranty which is valid for 2 years under normal use. To claim the warranty service, a user can contact Sears or return the product to the nearest Sears store. For further assistance or service, Sears can be contacted at 1-800-469-4663.
