3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79512
Background
The Craftsman Trimmer 358.795120 is a gas-powered line trimmer, manufactured by POULAN/WEEDEATER for Sears. It is primarily used for grass and weed trimming around residential areas. This trimmer is powered by a 25cc 2-cycle gas engine and has a straight shaft design. It is equipped with a weedwacker head that has a cutting diameter of 17 inches and uses a 0.080 inch thick nylon cutting line.
The Craftsman Trimmer operates by mixing gasoline and 2-cycle engine oil in a 40:1 ratio to fill up its 10 ounce fuel tank. The trimmer is started using a choke and pull starter rope and once it is running, the nylon line trimmer head rotates to cut grass and weeds. The trimmer has a feature that allows more line to be advanced with a tap on the ground while it's running. It also includes an adjustable assist handle for user comfort and an on/off switch to stop the engine.
Technical Specifications
- Model Number: 358.795120
- Product Type: Trimmer
- Engine: 25cc/1.5 cu.in. 2-cycle gas engine
- Cutting path: 17 inches
- Cutting line: 0.080 inch diameter
- Fuel: 40:1 gas/oil premix (3.2 oz oil per gallon gas)
- Fuel capacity: 10 fluid ounces
- Weight: 10 lbs
Warranty
The Craftsman 25cc Gasoline Weedwacker comes with a full one-year warranty through Sears from the date of purchase. This warranty covers any defects in materials or workmanship, but excludes normal wear items such as trimmer line, spark plug, and air filter. Commercial or rental use of the product is covered under the warranty for 90 and 30 days respectively. To claim the warranty, the unit needs to be returned to any Sears store or service center in the United States along with a proof of purchase. Additionally, the product has a separate two-year warranty covering defects in emissions-related parts including the carburetor and ignition system, which can be claimed through Sears service centers.
