3 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.795121
Background
The Craftsman Trimmer 358.795121 is a gardening tool designed for trimming grass, weeds, and light vegetation. It is powered by a 25cc, 1.5 cu. in., 2-cycle gas engine and features a curved shaft design. The trimmer has a cutting path of 17 inches, and uses a 0.080 inch diameter nylon trimming line, which advances when the head is tapped on the ground. The fuel capacity of the trimmer is 6 fl oz, and it operates on a 40:1 gasoline to oil ratio, which equates to approximately 3.2 oz of oil per 1 gallon of gasoline.
In terms of operation, the Craftsman Trimmer 358.795121 requires priming the fuel, moving the choke to full, and pulling the starter rope to start. The choke then needs to be moved to half until the engine warms up. During use, the trimmer line advances by tapping the rotating head on the ground while holding the throttle open. The unit is held at waist level, sweeping from right to left for trimming. Regular maintenance of the trimmer includes checking for loose fasteners, cleaning the air filter every 5 hours of use, and changing the spark plug yearly.
Technical Specifications
- Model Number: 358.795121
- Product Type: Trimmer
- Engine: 25cc, 1.5 cu. in., 2-cycle
- Cutting path: 17 inches
- Trimmer line diameter: 0.080 inch
- Fuel mixture ratio: 40:1 (gasoline to oil)
- Fuel capacity: 6 fl oz
Warranty
The Craftsman Trimmer 358.795121 comes with a comprehensive full one-year warranty. This warranty is designed to cover any defects that may arise in the materials or the workmanship of the product, with some exceptions. The warranty does not extend to expendable parts such as the nylon line, spark plug, and air filter. The warranty remains valid provided that the trimmer is used and maintained properly as per the instructions outlined in the manual. However, it's important to note that the warranty period is shortened for commercial and rental use, being reduced to 90 days and 30 days respectively. To claim the warranty, one must adhere to the conditions stated in the instruction manual and follow the procedure set forth by the manufacturer.
