2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.7918
Background
The Craftsman Trimmer 358.791800 is a gas powered garden tool produced by POULAN/WEEDEATER for Sears. It is designed for cutting grass and weeds with a cutting path of 17 inches. This trimmer uses a 0.095 inch diameter line for cutting. It operates with a 32cc, 1.9 cu.in. 2-cycle engine, which requires a fuel mix ratio of 40:1, equating to 3.2 oz of oil for every 1 gallon of gas. The trimmer also includes a recoil starter for operation.
In terms of operation, the user starts the trimmer by setting the on/off switch to ON, pressing the primer bulb 6 times, adjusting the start lever to START, and pulling the starter rope steadily. The trimmer line extends approximately 2 inches each time the head is tapped on the ground while the engine is running at full throttle. The trimmer is designed to use only a 0.095 inch line. Regular maintenance of the Craftsman Trimmer 358.791800 includes cleaning the engine air filter every 5 hours, replacing the spark plug yearly, and servicing or replacing the muffler and spark arresting screen after every 50 hours of use.
Technical Specifications
- Model Number: 358.791800
- Product Type: Trimmer
- Engine: 32cc, 1.9 cu.in. 2-cycle gas powered
- Cutting Path: 17 inches
- Cutting Line: 0.095 inch diameter
- Fuel Mix Ratio: 40:1 (3.2 oz oil per 1 gallon gas)
- Starter: Recoil
- Operation: Manual start with on/off switch, primer bulb, and starter rope
- Line Advancement: Tapping head on ground with engine at full throttle
- Line Limit: Limited by the line limiter blade on the shield
- Recommended Line: 0.095 inch diameter
- Manufacturer: Sears
Warranty
The Craftsman Trimmer 358.791800 comes with a one-year full warranty that covers any defects that may occur due to material or workmanship. However, parts that are expected to wear out with normal use, such as the cutting line, spark plug, and air filter, are not covered under this warranty. Additionally, the warranty period reduces to 30 days if the trimmer is used for commercial purposes.
