2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79182, 358.791820
Background
The Craftsman Trimmer 358.791820 is a string trimmer that operates on gasoline. It is equipped with a 25cc 2-cycle air-cooled engine and a displacement of 1.5 cubic inches. The cutting path that it can cover spans 17 inches, with a line diameter of 0.080 inches. It utilizes a fuel mix ratio of 40:1, specifically 3.2 oz of oil per 1 gallon of gas. The recommended oil for this model is Craftsman synthetic 2-cycle air cooled engine oil, and it uses unleaded gasoline as fuel.
The trimmer is designed with a curved shaft and an adjustable assist handle for user convenience. It also features a debris shield to protect the user from thrown debris. Additionally, it incorporates an automatic line feed mechanism and an easy start technology for quick starting. For maintenance, it is suggested to clean the unit and labels after each use, replace or clean the air filter every five hours of use, and check for loose or damaged parts before each use. It is also recommended to use fresh fuel and stabilize fuel for longer storage, and to drain fuel for storage over 30 days.
Technical Specifications
- Engine: 25cc 2-cycle air cooled
- Displacement: 1.5 cu.in.
- Cutting path: 17 inches
- Line diameter: 0.080 inches
- Fuel mix ratio: 40:1 (3.2 oz oil per 1 gallon gas)
- Recommended oil: Synthetic 2-cycle air cooled engine oil
- Fuel type: Unleaded gasoline
- Design: Curved shaft
- Handle: Adjustable assist
- Protection: Debris shield
- Line feed: Automatic
- Starting method: Easy start technology
Warranty
The Craftsman Trimmer 358.791820 comes with a 1-year full warranty that covers any defects in materials and workmanship. However, it's important to note that this warranty does not cover expendable parts such as the cutting line, spark plug, and air filter. Should the trimmer be used commercially, the warranty period is reduced to 90 days. If you need to claim the warranty, refer to the operating manual for details or contact the manufacturer directly. Always ensure to provide the product's model number and a detailed description of the defect or issue.
