2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79158
Background
The Craftsman Trimmer 358.791580 is a gardening tool designed for trimming, edging, scalping, and mowing in areas that a standard lawn mower may struggle to reach. It is fueled by a 32cc, 1.9 cu. in. 2-cycle gas engine, and requires the user to mix gasoline and 2-cycle engine oil in a 40:1 ratio. The trimmer is equipped with an adjustable assist handle for user convenience and utilizes a nylon cutting line to cut grass, weeds, and light brush.
The Craftsman Trimmer 358.791580 has a fuel tank with a capacity of 6 fl. oz. and a cutting width of 15 inches when utilizing the included trimmer head. It has a cutting line diameter of 0.080 inches with a red line and 0.095 inches with a black line. The weight of the trimmer is 10 lbs without fuel and cutting head, and it measures 69 inches in length. The trimmer is started with a pull recoil starter. Regular maintenance activities include replacing the air filter, cleaning debris from various parts of the trimmer, checking and replacing the trimmer line when worn, cleaning the spark plug and the exterior of the unit.
Technical Specifications
- Engine: 32cc, 1.9 cu. in. 2-cycle gas engine
- Fuel: Requires mixture of gasoline and 2-cycle engine oil in a 40:1 ratio
- Fuel tank capacity: 6 fl. oz.
- Cutting width: 15 in. with included trimmer head
- Cutting line diameter: Red line is 0.080 in., black line is 0.095 in.
- Handle: Assist handle adjustable to different angles
- Weight: 10 lbs without fuel and cutting head
- Length: 69 in.
- Included accessories: Shield, trimmer head
Warranty
The Craftsman Trimmer 358.791580 comes with a one-year warranty from Sears, which protects against defects in materials or workmanship. However, this warranty does not cover expendable parts such as the air filter, spark plug, and nylon trimmer line. If the trimmer is used for commercial purposes, the warranty coverage period shortens to 90 days. To claim the warranty, customers are advised to contact Sears directly or visit their nearest Sears store with the faulty trimmer and the original purchase receipt.
