2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79117
Background
The Craftsman Trimmer 358.791170 is a tool used for trimming grass and weeds. It is designed with a 33cc 2-cycle gasoline engine, which requires a mixture of gasoline and 2-cycle engine oil at a ratio of 40:1. The trimmer is capable of a 17-inch cutting width with the included trimmer head. It accepts a 0.080 inch trimmer line. Without the trimmer head, the tool weighs approximately 10 lbs. The trimmer has a maximum power output of 1.25 HP, a fuel tank capacity of 0.3 liters, and can reach a maximum unloaded speed of 7800 rpm. The spark plug used in this trimmer is a Champion RCJ-6Y.
The Craftsman Trimmer 358.791170 is used for maintaining lawns and gardens by trimming overgrown grass and weeds. Its 33cc engine and 17-inch cutting width allow for efficient trimming of large areas. The trimmer can be operated using a start lever and a primer bulb, and it can be stopped by pushing the stop switch. The product's dimensions are 60 inches in length, 11 inches in width, and 12 inches in height.
Technical Specifications
- Engine Type: 2-stroke, air-cooled, 33 cc displacement
- Power Output: 1.25 HP
- Fuel: Requires a mix of gasoline and 2-cycle engine oil at a 40:1 ratio
- Fuel Tank Capacity: 0.3 liters
- Cutting Width: 17 inches
- Line Diameter: Accepts 0.080 inch trimmer line
- Weight: 10 lbs (without trimmer head)
- Speed: Maximum unloaded speed of 7800 rpm
- Spark Plug: Champion RCJ-6Y
- Dimensions: 60 inches long, 11 inches wide, 12 inches high
- Attachments: Comes with a trimmer attachment, others like cultivator, blower, brushcutter are optional.
Warranty
The Craftsman Trimmer 358.791170 comes with a consumer warranty that lasts for 2 years. This warranty provides coverage for defects in materials and workmanship. However, it should be noted that normal wear items such as trimmer line, spark plugs, and filters are excluded from the warranty. Also, the warranty becomes invalid if the product is damaged due to improper use or lack of maintenance. To claim the warranty, one should typically contact the manufacturer's customer service or follow the instructions provided in the product manual.
