2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79106
Background
The Craftsman Trimmer 358.791060 is a gas-powered string trimmer designed for cutting grass and weeds. Manufactured by POULAN/WEEDEATER for Sears under the Craftsman brand, it features a 32cc (1.9 cu.in.) 2-cycle engine that operates on unleaded gasoline. The trimmer is compliant with both EPA and California Air Resources Board (CARB) emissions guidelines. The device includes a muffler that contains chemicals known to the State of California to cause cancer.
The Craftsman Trimmer 358.791060 has an ON/OFF switch to control the engine and a primer bulb that aids in starting the engine by delivering fuel to the carburetor. The start lever assists in starting by supplying fuel to the engine, and it includes a starting system designed for smooth pulling of the starter rope. The trimmer has a 17-inch cutting path and uses a 0.080 inch diameter line. The line limiter blade on the shield cuts excess line to the proper length, and tapping the head on the ground advances the line. Regular maintenance recommended includes cleaning the air filter every five hours, inspecting the muffler every 50 hours, and replacing the spark plug yearly. The carburetor can be adjusted as needed. For storage, it's recommended to drain the fuel, start the engine until it stops to empty the carburetor and clean the unit before storing it for over 30 days.
Technical Specifications
- Engine Type: 32cc (1.9 cu.in.) 2-cycle
- Fuel Type: Unleaded gasoline
- Starting System: "SS-Pull" system for smooth pulling of the starter rope
- Cutting Path: 17 inches
- Line Diameter: 0.080 inch
- Line Advance Method: Tapping the head on the ground
- Adjustable Feature: Carburetor can be adjusted as needed
- Optional Attachments: Edger, cultivator, blower, brushcutter, pole pruner via coupler
- Storage Recommendations: Drain fuel and clean unit before long term storage
Warranty
The Craftsman Trimmer 358.791060 comes with a one-year full warranty. This warranty covers any defects in materials or workmanship but does not extend to expendable parts such as the cutting line, spark plug, and air filter. If the trimmer is used for commercial or rental purposes, the warranty remains valid for only 30 days from the date of purchase. In order to claim the warranty, repairs should ideally be performed by Sears Service Centers, but it is not strictly required.
