2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.791042
Background
The Craftsman Trimmer 358.791042 is a garden tool that is used to cut grass and weeds. It is powered by a 32cc, 1.9 cu.in. 2-cycle gas engine, which requires unleaded gasoline mixed with 2-cycle oil at a ratio of 40:1. The trimmer uses a string as its cutting mechanism, which is fed from a bump feed trimmer head. The trimmer line is dispensed when the head of the device is tapped on the ground. The specific fuel capacity, cutting width, weight, and dimensions of the trimmer are not specified.
This trimmer is designed for homeowners and is equipped with a straight shaft. It can be adapted for different tasks, such as edging or cultivation, by utilizing the Powerhead Convertible feature. The trimmer starts by priming the bulb and pulling the starter rope. An on/off switch is included to halt the engine. The trimmer is designed to use Craftsman brand trimmer line, with red line recommended for grass and weeds, and black line suggested for heavier vegetation.
Technical Specifications
- Model Number: 358.791042
- Product Type: Gas-powered Trimmer
- Engine: 32cc, 1.9 cu.in. 2-cycle gas engine
- Fuel: Unleaded gasoline mixed with 2-cycle oil at a ratio of 40:1
- Cutting Line: Trimmer line - red line for grass/weeds, black line for heavier vegetation
- Additional Features: Straight shaft, bump feed trimmer head, convertible to other attachments like an edger or cultivator, debris shield and line limiter blade, priming bulb and pull starter, on/off switch
Warranty
The Craftsman Trimmer 358.791042 comes with a 1-year full warranty which is valid at Sears parts and service centers. This warranty covers any defects in materials and workmanship from the date of purchase. However, it should be noted that normal wear items like trimmer line, spark plugs, and air filters are not included in the coverage of the warranty. If the trimmer is used for commercial purposes, the warranty period is reduced to 90 days. To claim the warranty, the product must be taken to a Sears part and service center where the necessary checks will be made and the warranty claim processed.
