2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.791041
Background
The Craftsman Trimmer 358.791041 is a gas-powered yard maintenance tool manufactured by Sears. This trimmer is equipped with a 32cc 2-cycle engine and a 17-inch cutting path that uses 0.080-inch line. One of the key features of this product is its Convertible attachment system, which allows it to transform into other yard tools such as an edger, cultivator, blower, brushcutter, or pruner. The conversion requires Quick-Change attachments which are available separately.
The Craftsman Trimmer 358.791041 also includes features designed to enhance usability. For instance, it has a Sim-Pull assisted start system that makes engine starting smoother. An adjustable ergonomic assist handle provides comfort during use, and the ON/OFF switch is conveniently positioned on the trigger handle. Regular maintenance, such as cleaning the air filter and replacing the trimmer line as needed, can help keep the trimmer working optimally.
Technical Specifications
- Model Number: 358.791041
- Product Type: Trimmer
- Engine: 32cc/1.9 cu.in. 2-cycle
- Cutting path: 17 inches
- Line thickness: 0.080 inch
- Fuel tank capacity: 21 oz (0.6 L)
- Weight: 10.1 lbs (4.6 kg) without attachment
- Convertible attachment system: Yes, optional Quick-Change attachments sold separately
- Start system: Assisted start system
- Adjustable handle: Yes, ergonomic assist handle adjustable into different positions
- ON/OFF switch location: On the trigger handle
Warranty
The Craftsman Trimmer 358.791041 is covered by a 2-year limited warranty. This warranty covers any defects in the materials and workmanship of the product, provided it is used for non-commercial purposes. However, it's important to note that expendable parts such as spark plugs, air filters, and trimmer line are not covered by this warranty as these items can naturally wear out over time within the 2-year period. Regular maintenance items are also excluded from this warranty coverage.
