2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.79103
Background
The Craftsman 358.791030 is a gas-powered string trimmer, designed for yard use and occasional trimming tasks. It was manufactured by Poulan/WeedEater for Sears under the Craftsman brand and released in 2006. The trimmer is equipped with a 25cc, 1.5 cubic inch, 2-cycle gas engine and uses a 40:1 gas to oil mix for fuel. It has a fuel capacity of 10 fluid ounces. The trimmer has a cutting width of 17 inches and uses nylon cutting line with a diameter of 0.080 inches. The trimmer weighs 11 lbs and includes an adjustable assist handle.
The Craftsman 358.791030 features an on/off switch, a primer bulb for easy starting, and a "Sim-Pull" starting system. It also includes a coupler for quick attachment changes, a debris shield with a line limiter blade, and an adjustable assist handle for comfort and control. The starting process involves priming the fuel bulb, turning on the on/off switch, setting the start lever to start, and pulling the starter rope. The "Sim-Pull" system allows for a steady, controlled pull of the rope. Once started, the trimmer head spins at 8000 RPM for cutting grass, weeds, and light vegetation. The integrated coupler allows for quick changes between edger, cultivator, blower, and other attachments for a variety of uses. The trimmer requires regular maintenance including periodic inspection of parts for damage, cleaning the air filter, replacing the spark plug yearly, and checking the muffler outlet screen after 50 hours of use.
Technical Specifications
- Model Number: 358.791030
- Product Type: Trimmer
- Engine: 25cc, 1.5 cu. in., 2-cycle gas
- Fuel Mix: 40:1 gas to oil mix
- Fuel Capacity: 10 fl oz
- Cutting Width: 17 in.
- Cutting Line Diameter: 0.080 in.
- Weight: 11 lbs
- Handle: Adjustable assist handle
- Starting System: Manual pull-start with primer bulb and ON/OFF switch
- Maximum RPM: 8000
- Attachment System: Integrated coupler for attachment changes
