2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.791031
Background
The Craftsman Trimmer 358.791031 is a gas-powered trimmer manufactured by Poulan/Weedeater for Sears. It operates on a 25cc, 1.5 cu. in. 2-cycle engine and uses a 40:1 gas to oil mix. The trimmer is designed with a straight shaft and has a cutting path of 17 inches. It uses a 0.080 inch diameter trimmer line. Notable features of the trimmer include the capacity to swap attachments, an "Sim-pul" system for convenient starting, an adjustable assist handle, an ON/STOP switch, a primer bulb, and a debris shield with a line limiter blade.
The trimmer is compatible with multiple attachments, enhancing its versatility. These attachments include a trimmer head, edger, cultivator, blower, brushcutter, and pruner. Furthermore, the product has maintenance guidelines such as cleaning the air filter every 5 hours, inspecting the muffler/spark arrestor after 50 hours, replacing the spark plug yearly, and using fresh gas with fuel stabilizer during storage. For long-term storage, it is recommended to drain the fuel.
Technical Specifications
- Model Number: 358.791031
- Product Type: Trimmer
- Engine: 25cc, 1.5 cu. in. 2-cycle gas powered
- Fuel: 40:1 gas to oil mix (87 octane unleaded gasoline with synthetic oil)
- Cutting Path: 17 inches
- Line Size: 0.080 inch diameter
- Attachments: Trimmer head (included), edger, cultivator, blower, brushcutter, and pruner (optional)
- Additional Features: System for swapping attachments, easy starting system, adjustable assist handle, ON/STOP switch, primer bulb, debris shield with line limiter blade
Warranty
The Craftsman Trimmer 358.791031 comes with a 1-year full warranty. This warranty specifically covers defects in the materials and workmanship of the product. In the event that a warranted part needs repair or replacement, the warranty would cover it. However, it is important to note that any damage arising from improper use or lack of maintenance is not covered by this warranty. To claim the warranty, you'd typically need to present the faulty part along with proof of purchase, such as a receipt, to the manufacturer or authorized dealer. Remember, maintenance and repair can be performed by anyone, not just professionals, and it's important to follow the product’s user manual to avoid invalidating the warranty.
