2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
358.36026
Background
The Craftsman Trimmer 358.360260 is a gasoline-powered chainsaw produced for Sears under the Craftsman brand. The product is equipped with a 2.2 cu.in./36cc 2-cycle air-cooled engine and intended for infrequent use. This chainsaw is equipped with a 16-inch bar and a low-kickback chain.
Notably, the Craftsman Trimmer 358.360260 is designed for outdoor tasks such as cutting logs and pruning trees. It includes a choke/fast idle lever and primer bulb for cold starts and an adjustable screw for chain tensioning. A bar-mounted chain oiler provides lubrication during use, and the engine features a spark arrestor screen. The product weighs 10 lbs and measures 17 in. x 8 in. x 11 in. The fuel tank has a capacity of 10 fl.oz. (300 ml) and the oil tank can hold 6.8 fl.oz. (200 ml). Its fuel mixture ratio is 40:1, equivalent to 3.2 fl.oz. oil per 1 gallon of gasoline.
Technical Specifications
- Engine: 2.2 cu.in./36cc 2-cycle air cooled gasoline engine
- Power Output: 2.0 HP
- Bar Length: 16 inches
- Chain Type: Low-kickback chain
- Fuel Tank Capacity: 10 fl.oz. (300 ml)
- Oil Tank Capacity: 6.8 fl.oz. (200 ml)
- Fuel Mixture: 40:1 (3.2 fl.oz. oil per 1 gallon gasoline)
- Weight (dry): 10 lbs
- Dimensions: 17 in. x 8 in. x 11 in.
Warranty
The Craftsman Trimmer 358.360260 comes with a 2-year consumer warranty. This warranty covers any defects in materials or workmanship for non-commercial use. However, it's important to note that certain components like the bar, chain, spark plug, and air filter are classified as consumable parts and are, therefore, not covered by this warranty. In order to claim the warranty, refer to the information provided in the Craftsman Trimmer 358.360260 Instruction Manual or contact the manufacturer directly. Ensure to keep your proof of purchase, as it may be required during the warranty claim process.
