2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
316.795002
Background
The Craftsman Trimmer 316.795002 is a string trimmer produced by Ryobi America Corp for Sears under the Craftsman brand. This gasoline-powered tool is designed with a curved shaft, specifically intended for residential lawn maintenance. It is equipped with a 25cc 2-cycle engine and uses easy start technology. The trimmer head utilizes .080 inch monofilament line and is furnished with an auto-feed system that advances new line when necessary. The trimmer, which weighs 12 lbs, is designed to accept various attachments such as edger blades and brush cutters.
The Craftsman Trimmer 316.795002 features an over-the-shoulder harness with adjustable straps for comfortable use and a loop-style handle that includes a conveniently located throttle trigger and stop switch. The trimmer head can be positioned either vertically or horizontally, depending on the user's trimming needs. Additional technical specifications include a cutting width of 17 inches, a fuel capacity of 0.95 qt, and overall dimensions of 75 in x 11 in x 11 in. This model is part of the 300 series line of string trimmers and brushcutters, and although it has been replaced by newer models, replacement parts may still be accessible.
Technical Specifications
- Model Number: 316.795002
- Product Type: Gasoline-powered string trimmer
- Engine: 25cc 2-cycle
- Starting Mechanism: Recoil pull with easy start
- Trimmer Head: Auto-feed with .080 inch monofilament line
- Attachments: Can accept attachments like edger blades and brush cutters
- Harness: Over-the-shoulder with adjustable straps
- Handle: Loop style with throttle trigger and stop switch
- Orientation: Trimmer head can be oriented vertically or horizontally
- Weight: 12 lbs
- Cutting Width: 17 inches
- Fuel Type: Mixed gasoline and 2-cycle oil
- Fuel Capacity: 0.95 quarts
- Dimensions: 75 in x 11 in x 11 in
Warranty
The Craftsman Trimmer 316.795002 comes with a 2-year limited warranty. This warranty covers any defects that may arise due to materials or workmanship for a period of 2 years from the original date of purchase. However, please note that this warranty is limited to non-commercial use by the original purchaser. The warranty for the engine is separately covered by the engine manufacturer. To claim the warranty, it is advisable to refer to the manufacturer's website or contact their customer service directly.
