2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
316.795001
Background
The Craftsman Trimmer 316.795001, a gardening tool manufactured by Craftsman, operates on a 25cc 2-cycle engine. This gas-powered string trimmer is designed with a 17 inches cutting width and uses a 0.095 inch monofilament line for cutting. It is equipped with an automated line feed system that supplies new trimmer line as needed, removing the need to manually advance the line.
This trimmer is designed to operate with a 50:1 gas-to-oil mixture and features a 14 oz fuel tank, enabling extended operation between refills. For air filtration, a foam pre-filter and a replaceable paper filter element are included. The trimmer's regular maintenance involves replacing the filter elements and ensuring the use of fresh fuel mixes. Furthermore, the trimmer can be converted into an edger with the use of an optional wheeled edging guide.
Technical Specifications
- Model Number: 316.795001
- Product Type: Gas-powered string trimmer
- Engine: 25cc 2-cycle engine
- Cutting Width: 17 inches
- Cutting Line: 0.095 inch monofilament line
- Fuel Tank Capacity: 14 oz
- Weight: 11 lbs
- Handle: Cushioned wrap-around handle with adjustable assist
- Convertible to Edger: Yes, with optional wheeled edging guide
- Air Filtration: Foam pre-filter and replaceable paper filter element
Warranty
The Craftsman Trimmer 316.795001 comes with a 2-year limited warranty. This warranty covers any defects in the materials and workmanship of the product. However, it's important to note that any misuse or improper maintenance could void this warranty. In order to claim the warranty, you will need to reach out to the authorized Craftsman service centers. Please ensure to keep any receipts or documents related to the purchase of the trimmer as they may be required during the claim process.
