2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.79202
Background
The Craftsman Trimmer 316.792020 is a string trimmer that operates on gasoline. It is produced by Ryobi America Corporation for Sears, under the Craftsman Brand. The trimmer is powered by a 25cc 4-cycle air-cooled engine and comes with two interchangeable trimmer heads. The specifications of the trimmer include a range of operating RPM from 6,800 to 9,300, an idle speed of 2,800 to 3,600 RPM, and an electronic ignition type. The trimmer uses SAE 30 oil, has an oil capacity of 2.2 oz, and requires unleaded gasoline for operation. The trimmer also features an auto rewind starter, a baffled muffler with a guard, and a manual spring return throttle.
The Craftsman Trimmer 316.792020 is primarily used for trimming grass and light weeds in residential areas. It is equipped with a starting system that allows for easier starts and also features a translucent fuel tank that enables the user to monitor the fuel level. The trimmer also has the option to be upgraded with an electric start. The trimmer line is 0.095 in and it has a total weight of 13 lbs without fuel, the cutting head, or handle. Regular maintenance such as changing the oil, cleaning the air filter, and replacing the spark plug is required for the trimmer.
Technical Specifications
- Engine: 25cc 4-cycle air cooled
- Engine displacement: 1.5 cu.in. (25cc)
- Operating RPM: 6,800-9,300 rpm
- Idle speed: 2,800-3,600 rpm
- Ignition type: Electronic
- Valve clearance: 0.003-0.006 in (0.076-0.152 mm)
- Spark plug gap: 0.025 in (0.635 mm)
- Oil type: SAE 30
- Oil capacity: 2.2 oz (60 ml)
- Fuel type: Unleaded gasoline
- Carburetor: Diaphragm, all-position
- Starter: Auto rewind
- Muffler: Baffled with guard
- Throttle: Manual spring return
- Fuel tank capacity: 12 oz (355 ml)
- Drive shaft housing: Aluminum tube
- Throttle control: Finger-tip trigger w/lockout
- Weight: 13 lbs (5.9 kg) without fuel, cutting head or handle
- Trimmer line: 0.095 in (2.41 mm)
Warranty
The Craftsman Trimmer 316.792020 comes with a full warranty provided by Sears. This warranty covers defects in materials or workmanship and is valid for 3 years from the date of purchase. If you find any such defect, you can claim the warranty by referring to the instructions provided in the user manual. It's important to note that the warranty only covers problems arising due to manufacturing defects and not any damage or defect caused by misuse, neglect, or improper operation of the trimmer. Therefore, maintaining the trimmer in accordance with the provided operating and maintenance instructions is crucial.
