2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.79186
Background
The Craftsman Trimmer 316.791860 is a gasoline-powered device designed for trimming grass and weeds. Manufactured by Ryobi America Corp for Sears under the Craftsman brand, it belongs to the 300 series of Craftsman trimmers. This trimmer is powered by a 2-cycle 25cc gasoline engine, which allows the trimmer to cut through tough grass and weeds. The trimmer uses a straight shaft design and has a cutting width of 17 inches with a 0.095 inch monofilament line. The device features a bump head string advance mechanism that allows the user to advance the trimmer line with a tap on the ground.
The Craftsman 316.791860 has a fuel tank capacity of 0.95 quarts and its weight is 11 lbs, making it convenient for long trimming sessions. To aid user comfort, it comes with an over-the-shoulder strap to help distribute the weight. This trimmer is designed for residential property maintenance and can effectively trim around fences, landscaping beds, and other areas that a lawn mower may not reach conveniently. Regular maintenance, such as cleaning or replacing the air filter and changing the spark plug according to the recommended schedule, is necessary for its proper functioning.
Technical Specifications
- Model Number: 316.791860
- Product Type: Trimmer
- Engine: 2-cycle 25cc gasoline engine
- Cutting Width: 17 inches
- Cutting Line: 0.095 inch monofilament line
- Fuel Tank Capacity: 0.95 quarts
- Weight: 11 lbs
Warranty
The Craftsman Trimmer 316.791860 comes with a 2-year limited warranty from the date of purchase. This warranty covers any defects that may occur in the materials and workmanship of the product. However, please note that the warranty does not extend to parts that wear out from normal use. To claim the warranty, you should typically contact Craftsman's customer service with details about the defect, your product model, and proof of purchase. It is advisable to keep your receipt or other proof of purchase safe to ensure a smooth warranty claim process.
