2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.7912
Background
The Craftsman Trimmer 316.791200 is a gardening tool designed to cut grass, weeds, and small plants in places where a lawn mower can't reach. Manufactured by Ryobi America Corp for Sears under the Craftsman brand, it operates on a 27 cc 2-stroke air cooled engine. The trimmer is capable of operating at over 6,800 rpm, with an idle speed of 2,800 - 3,400 rpm. It utilizes an electronic ignition system with a rocker on/off switch and features a 0.025 in spark plug gap.
The Craftsman Trimmer 316.791200 requires a fuel-to-oil ratio of 40:1 for its lubrication and has a fuel tank capacity of 14 fl oz. It is fitted with a diaphragm, all-position carburetor and uses an auto rewind starter system. The weight of the trimmer is 10 lbs without fuel or cutting attachment. It uses a specified cutting head to achieve a cutting path diameter of 16 inches. The trimmer also features a system that allows the use of attachments like an edger, cultivator, blower, brush cutter, pole saw, and hedge trimmer. The handle is adjustable for comfort and control. Regular maintenance of the trimmer involves cleaning the air filter every 10 hours of use and replacing the spark plug every 25 hours of use.
Technical Specifications
- Engine: 27 cc 2-cycle air cooled engine
- Engine displacement: 1.10 in (2.8 cm)
- Operating RPM: 6,800+ rpm
- Idle speed: 2,800 - 3,400 rpm
- Ignition type: Electronic with rocker on/off switch
- Spark plug gap: 0.025 in (0.635 mm)
- Lubrication: Fuel/oil mixture
- Fuel/oil ratio: 40:1
- Fuel tank capacity: 14 fl oz (414 ml)
- Carburetor: Diaphragm, all-position
- Starter: Auto rewind
- Weight: 10 lbs without fuel or cutting attachment
- Cutting mechanism: String trimmer head
- Cutting path diameter: 16 in (40.6 cm)
Warranty
The Craftsman Trimmer 316.791200 is backed by a full 2-year warranty. This warranty covers any defects in materials and workmanship that may arise. However, it's critical to note that there are certain limitations for commercial use, modifications, and normal wear. If your trimmer develops any issues within this warranty period that are due to material or workmanship defects, you are entitled to claim the warranty. To do so, please follow the instructions provided in the operator's manual, ensuring to have all relevant information – such as proof of purchase – on hand.
