2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.791191
Background
The Craftsman Trimmer 316.791191 is a gas-powered string trimmer. It is manufactured by Ryobi America Corp for Sears under the Craftsman brand. The trimmer has a 27 cc air-cooled 2-stroke engine with a maximum operating RPM of 6,800+. The fuel/oil ratio for this trimmer is 40:1 and has a fuel tank capacity of 14 fl oz (414 ml). The trimmer weighs 10 lbs (4.5 kg) without fuel and uses a line with a diameter of 0.095 in (2.41 mm). The cutting path diameter of this trimmer is 17 in (43.18 cm).
The Trimmer 316.791191 has an "Incredi-Pull" starting system and a "Bump Head" cutting head. The "Incredi-Pull" starting system reduces the effort required to start the engine. The "Bump Head" cutting head enables new line to be released without stopping the engine. The trimmer can be used with a variety of attachments such as edgers, blowers, pole saws, etc. The engine runs on a mixture of fresh unleaded gasoline and a high quality 2-cycle oil specifically designed for air-cooled engines.
Technical Specifications
- Engine type: 27 cc air-cooled 2-stroke
- Maximum RPM: 6,800+
- Idle RPM: 2,800-3,400
- Spark Plug Gap: 0.025 in (0.635 mm)
- Fuel/Oil Ratio: 40:1
- Fuel Tank Capacity: 14 fl oz (414 ml)
- Weight (without fuel): 10 lbs (4.5 kg)
- Line Diameter: 0.095 in (2.41 mm)
- Cutting Path Diameter: 17 in (43.18 cm)
Warranty
The Craftsman Trimmer 316.791191 comes with a 2-year full warranty that covers any defects in material and workmanship. This warranty does not extend to expendable parts that are subject to normal wear and tear. To claim the warranty, refer to the operator's manual or contact the manufacturer, Sears Brands Management Corporation.
