2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.79116
Background
The Craftsman Trimmer 316.791160 is a string trimmer that operates on a 2-cycle gas mechanism. The product, which is manufactured by Sears Brands, is designed primarily for residential use, specifically for lawn trimming and edging tasks. The trimmer is equipped with a 31cc 2-cycle engine and operates at a speed of 8,600 RPM, while maintaining an idle speed between 3,200 - 4,400 RPM. The fuel to oil ratio of the device is 40:1, with a fuel tank capacity of 10 fl. oz. The weight of the trimmer, without fuel, ranges between 10-11 lbs.
The 316.791160 trimmer features a curved shaft design that ensures user comfort. The engine is started using a recoil starter and the handle can be adjusted as per user's convenience. The trimmer head is designed such that it allows for easy line replacement without having to disassemble the head. The device comes pre-loaded with dual spiral cutting lines, each 0.095 inches in diameter. Additionally, the trimmer has a convertible coupler that enables quick attachment changes to other yard tools.
Technical Specifications
- Engine Type: Air-cooled, 2-cycle
- Operating RPM: 8,600 rpm
- Idle Speed RPM: 3,200 - 4,400 rpm
- Spark Plug Gap: 0.025 in (0.635 mm)
- Fuel/Oil Ratio: 40:1
- Fuel Tank Capacity: 10 fl.oz (296 ml)
- Weight (without fuel): 10-11 lbs (4.5 - 5 kg)
- Line Diameter: 0.095 in spiral cutting line
Warranty
The Craftsman Trimmer 316.791160 comes with a 2-year limited warranty provided by Sears Brands Management Corporation. This warranty covers any defects in the materials used or the workmanship for a period of 2 years from the date of purchase. However, it is important to note that this warranty becomes void if the product is used for commercial purposes or if it is rented out. In order to claim the warranty, the user should typically contact the Sears Brands Management Corporation, providing proof of purchase and details of the defect. It is recommended to refer to the original product manual or the company website for specific procedures and contact information related to warranty claims.
