2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.79108
Background
The Craftsman Trimmer 316.791080 is a gas-powered string trimmer. This equipment is designed with an air-cooled 2-cycle engine with a displacement of 27cc and a maximum operating speed of over 6,800 rpm. The engine uses an electronic ignition system with a rocker on/off switch, and it operates on a 40:1 fuel/oil mixture. The fuel capacity of the trimmer is 14 fluid ounces.
The cutting head of the trimmer features a bump head design with a 3-inch line spool and uses a 0.095-inch diameter line. The cutting diameter is 16 inches. The steel tube shaft housing of the trimmer allows for changes in attachments. The manual throttle control comes with a spring return. The start-up process of the trimmer is facilitated by a system for easier pull starts and an automatic rewind starter. The trimmer weighs approximately 10 lbs without fuel or any cutting attachment. The trimmer can be used for cutting grass, light weeds, and for edging. Optional attachments such as cultivators, hedge trimmers, and pole saws can be used with this trimmer. Regular maintenance includes checking and changing the spark plug every 25 hours, cleaning the air filter every 10 hours, and using fresh fuel that is no more than 60 days old.
Technical Specifications
- Model Number: 316.791080
- Product Type: Trimmer
Engine Specifications:
- Type: Air-cooled 2-cycle engine
- Displacement: 27cc
- Maximum Operating Speed: 6800+ rpm
- Ignition: Electronic ignition with rocker on/off switch
- Fuel Type: 40:1 fuel/oil mixture
- Fuel Capacity: 14 fl oz
Cutting Head Specifications:
- Design: Bump head design with 3 inch line spool
- Line Diameter: 0.095 inch
- Cutting Diameter: 16 inch
Drive Specifications:
- Shaft Housing: Steel tube allowing attachment changes
- Throttle Control: Manual with spring return
Starting Specifications:
- Starting System: System for easier pull starts
- Starter: Automatic rewind
Physical Characteristics:
- Weight: Approx 10 lbs without fuel or cutting attachment
Warranty
The Craftsman Trimmer 316.791080 comes with a 2 year limited warranty. This warranty covers defects in materials and workmanship, ensuring that the product is free from such issues when used normally for its intended purpose. In order to claim the warranty, refer to the detailed process outlined in the operator's manual. It is essential to keep the purchase receipt or any proof of date of purchase, as it might be required to validate the commencement of the warranty period.
