2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
316.790101
Background
The Craftsman Trimmer 316.790101 is a gas-powered string trimmer manufactured by Ryobi for Sears under the Craftsman brand. It is designed for residential lawn care and light-duty landscaping tasks. The trimmer is powered by a 25cc 2-cycle engine and features an automatic line feed head, which advances the trimmer line without requiring user interaction. It is designed with a curved aluminum shaft and a 17-inch cutting swath. The trimmer has handles with cushions to reduce vibration and increase user comfort during extended use. The trimmer weighs approximately 10 lbs when empty.
Regular maintenance of the Craftsman 316.790101 includes checking and replacing the trimmer line, cleaning the air filter, replacing the spark plug, adjusting and lubricating cables, inspecting the hardware, and draining old fuel. These routine tasks can ensure the long-term performance and durability of the trimmer. It is recommended to use only the manufacturer's recommended replacement parts to ensure compatibility and proper operation.
Technical Specifications
- Model Number: 316.790101
- Product Type: Gas-Powered String Trimmer
- Design: Curved Shaft
- Engine: 25cc 2-cycle engine with easy pull starting
- Line Feed: Automatic line feed trimmer head
- Shaft Material: Aluminum
- Cutting Swath: 17 inches
- Handle Features: Cushion gripped handles for operator comfort
- Weight: Approximately 10 lbs dry weight
Warranty
The Craftsman Trimmer 316.790101 comes with a 2-year limited warranty provided by Craftsman. This warranty covers any defects in materials or workmanship for a period of two years from the date of purchase, as long as the trimmer is used for ordinary household use. However, the warranty becomes invalid if the trimmer is used for commercial applications or if it's rented. It should be noted that the engine's warranty is separately covered by its manufacturer. In order to claim the warranty, you are required to contact Craftsman's customer service or return the trimmer to the retailer from where it was purchased, along with the proof of purchase. This warranty coverage is only applicable to the original owners who have a receipt of the purchase.
