2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.7117
Background
The Craftsman Trimmer 316.711700 is a string trimmer designed for cutting grass and light vegetation. Manufactured by Ryobi for Sears, it operates using a 2-stroke, air-cooled engine with a displacement of 29cc. The engine's idle speed ranges from 2800 to 3600 rpm, and it can reach an operating speed exceeding 6800 rpm. The trimmer employs a Champion RDZ4H spark plug and runs on unleaded gasoline, holding up to 14 fluid ounces of fuel.
This trimmer utilizes a cutting head that accepts 0.110-inch diameter cutting line, providing a cutting diameter of 14 inches. It also features a starting system designed to reduce the effort required to pull-start the engine. The trimmer includes a coupler that facilitates the use of additional tools such as edgers, blowers, and pole saws. It is also compatible with electric start accessories. Regular maintenance of this trimmer involves tasks such as oil changes, air filter cleaning or replacement, spark plug replacement, valve clearance adjustment, and cutting head cleaning.
Technical Specifications
- Engine Type: Air-cooled, 4-cycle, 2-stroke
- Engine Displacement: 1.8 cu. in. (29cc)
- Idle Speed: 2800-3600 rpm
- Operating Speed: Over 6800 rpm
- Valve Clearance: 0.003-0.006 in (0.076-0.152 mm)
- Spark Plug: Champion RDZ4H (gap 0.025 in/0.635 mm)
- Fuel Type: Unleaded gasoline
- Fuel Capacity: 14 fl oz (414 ml)
- Oil Type: SAE 30
- Oil Capacity: 3.04 fl oz (90 ml)
- Weight: 11.5-13 lbs without cutting head and fuel
- Cutting Head: Uses 0.110 in (2.79 mm) diameter cutting line
- Cutting Diameter: 14 in (35.6 cm)
Warranty
The Craftsman Trimmer 316.711700 comes with a 2-year warranty. This warranty covers any defects in the materials and workmanship of the product. To claim this warranty, you would need to provide proof of purchase showing that the product is within the warranty period. Details on how to claim the warranty, such as who to contact or where to send the product, are typically provided in the product's user manual or can be found on the manufacturer's website.
