2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.71147.1
Background
The Craftsman Trimmer 316.711471 is a gardening tool designed by RYOBI / Ryobi America Corp for Sears under the Craftsman Brand. The trimmer operates on a 2-cycle, 29cc, air-cooled engine which uses a 40:1 mixture of unleaded gasoline and 2-cycle oil. It is equipped with a bump head cutting head, using a 0.095-inch diameter cutting line with a length of 12 feet. The cutting path diameter is approximately 17 inches which can be used for grass cutting, light weed removal, edging, and decorative trimming around trees and fences.
To operate the trimmer, the fuel is mixed and filled into the 10.0 oz fuel tank capacity, the primer bulb is pressed 10 times, the choke is moved to full choke position, and the starter rope is pulled while holding the throttle. During operation, the bump head allows new trimming line to be released by tapping the bump knob on the ground while running at full throttle. Routine maintenance includes cleaning and oiling the air filter every 10 hours, replacing the spark plug every 25 hours, and ensuring fresh fuel use within 30 days of mixing. The product weighs between 10-11 lbs without fuel.
Technical Specifications
- Engine: Air-cooled, 2-cycle, 29cc, 1.52 cu in displacement
- Spark Plug: Champion RDJ7J, 0.025 in gap
- Fuel/Oil Ratio: 40:1 mixture
- Fuel Tank Capacity: 10.0 oz
- Weight: 10-11 lbs without fuel
- Cutting Head: Bump Head
- Cutting Line: 0.095 in diameter, 12 ft length
- Cutting Path: 17 in diameter
Warranty
The Craftsman Trimmer 316.711471 comes with a 2-year full warranty which covers any defects in materials and workmanship. Additionally, there is an 8-year limited warranty specifically for the outer metal shaft housing of the trimmer. To claim the warranty, servicing and parts are available from Sears parts centers. Please note that it is important to retain your proof of purchase in order to validate the warranty claim.
