2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.71137
Background
The Craftsman Trimmer 316.711370 is a gas-powered string trimmer produced by Sears Brands. It utilizes a 25cc 2-cycle air-cooled engine and is fitted with a starting system that is designed to make pull starts less strenuous.
This trimmer operates with a specific idle and operating RPM, uses a Champion RDJ7J equivalent spark plug, and requires a fuel/oil ratio of 40:1. It has a fuel tank capacity of 10 oz and weighs between 10 and 11 lbs without fuel. The trimmer mechanism is a bump head, which allows for the release of the line without the need to stop the engine. It uses a line with a diameter of 0.095 inches and has a cutting path diameter of 17 inches. The trimmer is started by adding a fuel mixture, pressing the primer bulb, adjusting the choke, and pulling the starter rope. It is stopped by releasing the throttle trigger and switching the on/off switch to the off position. Maintenance involves cleaning and re-oiling the air filter, checking or replacing the spark plug, using fresh unleaded gasoline with a 2-cycle oil mix, and replacing the trimmer line as needed.
Technical Specifications
- Model Number: 316.711370
- Product Type: Gas-powered String Trimmer
- Engine: 25cc 2-cycle air-cooled
- Idle Speed: 3,200 - 4,400 rpm
- Operating RPM: Over 6,300 rpm
- Spark Plug Gap: 0.025 in (0.635 mm)
- Spark Plug: Champion RDJ7J or equivalent
- Fuel/Oil Ratio: 40:1
- Fuel Tank Capacity: 10 oz (295 ml)
- Weight (without fuel): 10 - 11 lbs (4.5 - 5 kg)
- Trimmer Mechanism: Bump Head
- Line Diameter: 0.095 in (2.41 mm)
- Cutting Path Diameter: 17 in (43.18 cm)
Warranty
The Craftsman Trimmer 316.711370 comes with a comprehensive warranty. It offers a full two-year warranty that covers any defects in materials or workmanship. This ensures that if any part or component of the trimmer fails or malfunctions due to a manufacturing error within the first two years of use, it will be repaired or replaced by the company at no cost to the customer. In addition to this, the trimmer shaft housing is specifically covered for an additional eight years against defects. This means that this component of the trimmer has an extended warranty period of ten years in total. To claim the warranty, customers should refer to the information provided with the product upon purchase. This will usually involve contacting the manufacturer's customer service, providing proof of purchase, and describing the issue.
