2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.71119
Background
The Craftsman Trimmer 316.711190 is a gas powered trimmer, produced by Sears Brands, which is commonly utilized for the trimming of grass and light weeds in residential yards. This trimmer operates on a 29 cc 2-cycle air-cooled engine and is designed with a cutting head that uses a 0.110 inch diameter nylon cutting line. The trimmer offers a cutting path diameter of 14 inches. A distinguishing characteristic of the trimmer is its adjustable assistance handle, which can be tailored according to the user's height and comfort.
The Craftsman 316.711190 trimmer features a unique line feed system incorporated into its cutting head, which allows the user to advance the line without having to bump the head. This cutting diameter is suitable for managing small to medium sized yards. The trimmer also employs a ConvertibleTM coupler system that enables it to operate at various angles. This feature is particularly useful when the user needs to trim and edge in corners, or along fences and landscaping areas.
Technical Specifications
- Model Number: 316.711190
- Product Type: Trimmer
- Engine: 29 cc 2-cycle air-cooled engine
- Displacement: 1.52 cu. in. (29 cc)
- Idle Speed: 3,200 - 4,400 rpm
- Operating RPM: 6,900+ rpm
- Spark Plug Gap: 0.025 in. (0.635 mm)
- Spark Plug: Champion RDJ7J or equivalent
- Lubrication: fuel/oil mixture
- Fuel/Oil Ratio: 40:1
- Fuel Tank Capacity: 10.02 fl. oz (296 ml)
- Weight (without fuel): 10-11 lbs (4.5 - 5 kg)
- Cutting Mechanism: cutting head
- Line Diameter: 0.110 in (2.79 mm)
- Cutting Path Diameter: 14 in (35.56 cm)
Warranty
The Craftsman Trimmer 316.711190 has a 2 year full warranty that covers defects in material and workmanship from the date of purchase. The upper and lower metal trimmer shafts are given additional coverage under a limited 8 year warranty. However, the warranty does not cover expendable parts, product misuse, improper maintenance, or engine failure due to stale or improperly mixed fuel. To claim the warranty, one must refer to the full warranty details available on the Craftsman website.
