2 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
316.71102
Background
The Craftsman 316.711020 is a string trimmer notable for its 2-cycle gas powered engine. Manufactured by Sears Brands, this trimmer is primarily used for cutting grass and light weeds around yards. The engine, which is air-cooled, allows for sufficient power to carry out residential trimming tasks.
The trimmer comes with features that include a convertible coupler which permits the use of other attachments such as an edger or cultivator. Its cutting head is designed for hassle-free usage with a bump feed line advance feature. Additionally, the trimmer has a starting system that lessens the pull effort required. It also incorporates a full crankcase emissions control system. This trimmer requires regular maintenance for optimal performance, such as cleaning and re-oiling the air filter after every 10 hours of operation and inspecting the spark plug every 25 hours.
Technical Specifications
- Model Number: 316.711020
- Product Type: Gas powered string trimmer
- Engine: 29 cc 2-cycle air cooled
- Idle Speed: 2800-3400 rpm
- Operating Speed: Over 6300 rpm
- Spark Plug Gap: 0.025 in (0.635 mm)
- Spark Plug: Champion RDJ7J or equivalent
- Fuel/Oil Mix Ratio: 40:1
- Fuel Tank Capacity: 10.2 fl oz (296 ml)
- Weight: 10-11 lbs without fuel (4.5-5 kg)
- Cutting Head: Head with 0.110 in (2.79 mm) spiral line
- Cutting Diameter: 14 in (35.56 cm)
