15 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
271.281611
Background
The Craftsman Trimmer 271.281611, a product of the Craftsman brand, is a handheld string trimmer. This device is fundamentally utilized for residential lawn trimming and light-duty weed clearing. The trimmer utilizes a straight shaft gas system, powered by a 25cc 2-cycle engine. It incorporates easy start technology, which facilitates simple pull starts. The trimmer head operates with 0.080 inch monofilament line that is capable of bump feeding without the need to halt the unit. The Craftsman Trimmer 271.281611 is equipped with an adjustable assist handle and is adaptable for left or right-handed use. The straight shaft design enables the trimmer to reach under low obstacles efficiently.
The Craftsman Trimmer 271.281611 is optimal for homeowner yard maintenance tasks. It is designed to edge sidewalks, trim grass along fences and foundations, and clear light brush. The monofilament line can be bumped to advance more line without the need to stop the trimmer. The trimmer operates with unleaded gasoline and 2-cycle oil at a mixing ratio of 40:1. The trimmer line should be maintained at the optimal length and replaced when it becomes too short.
Technical Specifications
- Model Number: 271.281611
- Product Type: Trimmer
- Manufacturer: Craftsman
- Engine Type: 25cc 2-cycle gas powered with easy start technology
- Cutting Width: 17 inches
- Cutting Line: 0.080 inch monofilament
- Fuel Tank Volume: 14 fluid ounces
- Weight: 11 pounds
- Handedness: Can be configured for left or right hand use
- Shaft Type: Straight
- Handle Type: Adjustable assist handle
- Line Feed System: Bump head
Warranty
The Craftsman Trimmer 271.281611 comes with a 2-year limited warranty. This warranty is designed to cover any defects in both materials and workmanship that may occur during this period. To claim the warranty, proof of purchase is required. It's important to note that the warranty does not provide coverage for damages that result from misuse or lack of proper maintenance. So, regular upkeep is crucial to ensure the validity of the warranty.
