1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
320.27311
Background
The Craftsman Circular Saw 320.27311 is a tool designed for cutting wood, plywood, hardboard and other wood-based materials. The circular saw is manufactured by Chervon for Sears under the Craftsman Brand. The saw is powered by a 15 Amp, 5200 RPM motor for quick and efficient cutting. It also features a top-mounted blade spindle lock for easy blade changes, a built-in sawdust ejection chute to direct dust and chips away from the operator, and permanently lubricated ball bearings for smooth operation and extended lifespan.
The saw has a built-in LED light to illuminate the cutting area for enhanced visibility. Quick depth-of-cut adjustments are possible with a maximum depth of cut being 2 3/8-inches thick at 90 degrees and 1 13/16-inches thick at 45 degrees. The bevel cut scale on the saw adjusts from 0 to 56 degrees, with a positive stop at 45 degrees. The saw comes with a 24-tooth carbide-tipped steel general-purpose blade for fast and smooth cuts. The saw also includes an edge guide to help produce accurate cuts, a high-impact resistant carry/storage case and laser enhancing safety glasses.
Technical Specifications
- Model Number: 320.27311
- Product Type: Circular Saw
- Motor: 15 Amp
- No-load Speed: 5200 RPM
- Maximum Depth of Cut at 90 degrees: 2 3/8-in. thick
- Maximum Depth of Cut at 45 degrees: 1 3/8-in. thick
- Bevel Capacity: 0° to 56°
- Blade Diameter: 7 1/4-in.
- Blade Arbor: 5/8-in.
Warranty
The Craftsman Circular Saw 320.27311 comes with a one-year full warranty. This warranty covers any defects in material or workmanship that may occur within one year from the date of purchase. If the product fails due to such defects, customers can return it to any Sears store, parts and repair center, or other Craftsman outlet in the United States for free repair. If repair proves impossible, the product will be replaced. It's important to note that expendable parts like lamps, batteries, bits, or blades are not covered by this warranty. To claim the warranty, customers simply need to bring the product to a Sears store or authorized repair center. The warranty also provides specific legal rights to the customers, which may vary from state to state.
