4 Diagrams
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Models
113.2351
Background
The Craftsman Circular Saw 113.235100 is a non-compound miter saw that was manufactured by Emerson Electric Co. for Sears under the Craftsman brand. The product is designed to perform various types of cutting operations, such as miter cuts and bevel cuts. Miter cuts refer to angle cutting operations made across the width of the workpiece, while bevel cuts are angle cutting operations made through the face of the workpiece. The saw also allows for compound cuts, which are simultaneous bevel and miter cutting operations.
The saw operates with an AC motor that is universal and non-reversible. It has specifications of 2 maximum developed H.P., a voltage of 120, 12 amperes, 60 Hertz (cycles), is single phase, and has revolutions per minute (RPM) of 5000. The saw's motor specifications indicate that it is designed for use with a 120v, 15-amp branch circuit, and the shaft rotation at the blade end is clockwise. The miter saw also features a double insulation system, which provides a double thickness of insulation between the user and the tool's electrical system. This ensures that all exposed metal parts are isolated from the internal metal motor components with protecting insulation.
Technical Specifications
- Product Type: Circular Saw
- Model Number: 113.235100
- Motor Power: Maximum Developed 2 Horsepower
- Voltage: 120 volts
- Amperes: 12 amps
- Frequency: 60 Hertz
- Phase: Single
- RPM: 5000 rotations per minute
- Shaft Rotation (blade end): Clockwise
- Electrical Safety: Double Insulated
- Wire Sizes Required for 120v: 14 (0-25 length), 12 (26-50 length)
- Motor Safety Protection: Motor should be blown out or vacuumed frequently to keep sawdust from interfering with normal motor ventilation.
- Motor Performance: Motor may stall if overloaded or in case of rapid feed or too many start/stops in a short time.
- Blade Rotation: Clockwise
- Tool Weight: Heavy, requires assistance for lifting more than 10 inches.
Warranty
The Craftsman Circular Saw 113.235100 comes with a full one-year warranty. If the saw fails due to a defect in material or workmanship within one year from the date of purchase, Sears will repair it free of charge. To claim the warranty, simply contact the nearest Sears service center/department throughout the United States. It is important to note that this warranty applies only while the product is used in the United States. Please keep in mind that this warranty gives you specific legal rights, and you may also have other rights which vary from state to state.
