1 Answer 3 Score |
How can I tighten my steering? |
1 Answer 1 Score |
My alt isn’t charging my battery. Keeps draining the battery |
1 Answer 0 Score |
Other year and models that will fit my 1989 bronco |
1 Answer 0 Score |
How do I replace my rear ball bearings |
Models
This category covers 1987, 1988, 1989, 1990, 1991 Ford Bronco models.
Background and Identification
The Ford Bronco is a line of SUVs (sport utility vehicles) produced by Ford between 1965 to 1996. The Bronco was the first SUV marketed by Ford and was originally a compact design based on an independent chassis. The Ford Bronco II was a compact SUV based on the Ford Ranger between 1984 and 1990 and was replaced by the Ford Explorer. For the 2021 model year, Ford reintroduced the Bronco SUV with both two- and four-door variants. In 2021, the Bronco was marketed as a mid-sized competitor to the Jeep Wrangler.
The fourth-generation Ford Bronco was released in 1987 with the introduction of the eighth-generation Ford F-Series. The fourth-generation Bronco shares its front sheet metal with the F-150. The Bronco gained a reshaped front bumper, flatter front grille, composite headlights, and a reshaped hood. The vehicle also gained rounded wheel openings in the fenders. The Bronco’s interior added redesigned front seats, door panels, dashboard, controls, and instrument panels. Anti-lock brakes (ABS) became standard with the 1987 model. The 1987 model was also available with a push-button control option for its four-wheel-drive model.
Ford vehicles can be identified by the Ford emblem, which depicts the name “Ford” in a cursive font. Bronco SUVs include the name “Bronco” either in capital letters or cursive letters as well as the Bronco emblem, which depicts a bucking horse.
Technical Specifications
Body and Chassis:
- Class: Full-size SUV
- Body Style: 3-door SUV
Powertrain:
- Engine:
- 300 cu in (4.9 L) Straight-6
- 302 cu in (4.9 L) 302 V8
- 351 cu in (5.8 L) Windsor V8
- Transmission:
- 5-speed M5OD-R2 manual
- 3-speed C6 automatic
- 4-speed AOD automatic
- 4-speed E4OD automatic
Dimensions:
- Wheelbase: 2,700 mm (106.3 in)
- Length: 180.5 in (4,580 mm)
- Width: 79.1 in (2,010 mm)
- Height:
- 1987–1989: 74.0 in (1,880 mm).
- 1990–1991: 74.5 in (1,890 mm)
Additional Information
- Wikipedia: Ford Bronco
- Ford.com: 1987-1991 Ford Bronco
- Car and Driver: A Visual History of the Ford Bronco
