Click Image To Zoom
750 GB Hybrid Seagate SATA Hard Drive (New)
$199.95
Product code: IF107-110-1
Product Overview
Combining different genes, like mixing ethnic cuisines, can result in wonderful, mind-boggling fusions, but can occasionally fail miserably, like those lousy curried lasagna tacos I made last night. Discover a truly jaw-dropping, hybridized wonder in our 750 GB Hybrid Seagate SATA hard drive.
Hybrid technology from Seagate combines SSD and traditional hard drive technology to provide SSD speeds from an affordable high capacity hard drive. Adaptive Memory technology keeps the files and file types you access the most ready and available for instant transfer from SSD.
No software or operating system requirements, Adaptive Memory technology is self-contained and works like any SATA drive.
Compatibility
Identify your Mac
  • All MacBooks and MacBook Pros (excluding MacBook Air and MacBook Pro Retina)
  • All Intel Mac minis
Product Details
  • Capacity: 750 GB Unformatted
  • Speed: Hybrid, 7200 RPM with 80% faster access times
  • Interface: SATA
  • Form Factor: 2.5"
  • Dimensions: 2.5" (69.85mm) x .37" (9.5mm)
  $199.95
Condition:
New
Warranty:
3-year manufacturer warranty
Add to Cart »
6 Available
Quantity:
Compatibility
Mac Mini Late 2012
2.3 GHz (Quad i7, Late 2012)
2.5 GHz (Dual i5, Late 2012)
2.6 GHz (Quad i7, Late 2012)
Mac Mini Mid 2011
2 GHz (Quad i7, Mid 2011)
2.3 GHz (Dual i5, Mid 2011)
2.5 GHz (Dual i5, Mid 2011)
2.7 GHz (Dual i7, Mid 2011)
Mac mini Model A1176
1.5 GHz (Core Solo, A1176)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo, A1176)
Mac mini Model A1283
2 GHz (Core 2 Duo, A1283)
2.26 GHz (A1283)
2.53 GHz (A1283)
2.66 GHz (A1283)
Mac mini Model A1347
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
MacBook Core 2 Duo
1.83 GHz (Core 2 Duo)
2 GHz (C2D, Late 2006)
2 GHz (C2D, Mid 2007)
2 GHz (Early 2009)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz (Core 2 Duo)
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz (Core Duo)
2 GHz (Core Duo)
MacBook Pro 13" Unibody Early 2011
2.3 GHz (Early 2011)
2.7 GHz (Early 2011)
MacBook Pro 13" Unibody Late 2011
2.4 GHz (Late 2011)
2.8 GHz (Late 2011)
MacBook Pro 13" Unibody Mid 2009
2.26 GHz (Mid 2009)
2.53 GHz (Mid 2009)
MacBook Pro 13" Unibody Mid 2010
2.4 GHz (Mid 2010)
2.66 GHz (Mid 2010)
MacBook Pro 13" Unibody Mid 2012
2.5 GHz (Mid 2012)
2.9 GHz (Mid 2012)
MacBook Pro 15" Core 2 Duo Model A1211
2.33 GHz (Core 2 Duo)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz (Core Duo)
2 GHz (Core Duo)
2.16 GHz (Core Duo)
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
2.53 GHz (Mid 2009)
MacBook Pro 15" Unibody Early 2011
2 GHz (Early 2011)
2.2 GHz (Early 2011)
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz (Late 2008)
2.53 GHz (Late 2008)
2.66 GHz (Early 2009)
2.8 GHz (Late 2008)
2.93 GHz (Early 2009)
MacBook Pro 15" Unibody Late 2011
2.2 GHz (Late 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
MacBook Pro 15" Unibody Mid 2009
2.66 GHz (Mid 2009)
2.8 GHz (Mid 2009)
3.06 GHz (Mid 2009)
MacBook Pro 15" Unibody Mid 2010
2.4 GHz (Mid 2010)
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2010)
MacBook Pro 15" Unibody Mid 2012
2.3 GHz (Mid 2012)
2.6 GHz (Mid 2012)
2.7 GHz (Mid 2012)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
MacBook Pro 17" Unibody
2.53 GHz (Mid 2010)
2.66 GHz (Mid 2010)
2.8 GHz (Mid 2009)
2.8 GHz (Mid 2010)
3.06 GHz (Mid 2009)
MacBook Pro 17" Unibody Early 2011
MacBook Pro 17" Unibody Late 2011
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
MacBook Unibody Model A1278
2 GHz (A1278)
2.4 GHz (A1278)
MacBook Unibody Model A1342
2.26 GHz (A1342)
2.4 GHz (A1342)
Stories
My Problem
No issues...great info
My Fix
My Advice
Excellent product, installation went perfect
My Problem
The Ole harddrive was absolutely filled - No place for change of MAC OS X Version
My Fix
The repair went very well - Did not use any Disk Cloning tools Just Disk Utolities and Time Machine
My Advice
Just format your new drive with MAC OS X Disk Utilities as a Bootable Partition - Do a restore from Time Machine to Your New Drive - Test it as You Boot Your new drive from a USB or Firewire atachment - Going Well OK - Swap Your Physical Drives
My Problem
I was running out of disk space on my 200GB drive
My Fix
It took about 4 hours to migrate my old HDD to the new one, using the Firewire 800 interface of the external HDD enclosure you sell. 1F107-097-1.
The actual replacement of the drive in the MacBook Pro took about an hour or less.
My Advice
The install went exactly as documented in the guide for the regular 750GB drive. Some additional information from my experience:
When the data migration to the new drive finished (a little less than 4 hours with your firewire 800/USB 2.0 case - I used the firewire connector) the access light was still flashing when I closed SuperDuper. I wasn't sure if the solid state drive portion of the drive was still destaging data to the disk. I left it run for about 30 minutes and then ejected the drive. Activity finally stopped.
2. The small cables at the front top of the HDD are routed through a channel to get to the drive. Put the small cable in first, with the larger, more heavily insulated cable on top. They need to be in the channel so they aren't smashed by the keyboard assembly.
3. There is a breather hole on the 750GBGB Hybrid drive that is right where the ribbon cable ends near the connectors. Be careful when resticking the ribbon cable, that it does not cover the breather hole on the top of the drive. Same goes when reinstalling the yellowish tape that holds the drive cables down.
4. When I booted for the first time, it took about 2 or 3 minutes of gray screen until the Apple logo came up. Then another couple minutes of gray screen until my desktop appeared. Be patient.
My MacBook Pro not only has much more disk space but runs much, much faster! The upgrade is very easy to do.
My Problem
I needed more room on my hard drive due to a large music library, a large number of pictures and video, etc.
My Fix
The repair went quickly and easily with no problems. I took advantage of having the laptop open to clean up dust with some canned air.
My Advice
Keep anti-static bags from previous upgrades, they make great places to place sensitive equipment during a job.
