Click Image To Zoom
Customers also bought
PC3-8500 4 GB RAM Chip
$99.95
26 Bit Driver Kit
$14.95
T10 Torx Screwdriver
$4.95
T8 Torx Screwdriver
$4.95
Installation Guides
iMac G5 17" Model A1058
Difficulty: Moderate
iMac G5 17" Model A1144
iMac G5 20" Model A1076
iMac G5 20" Model A1145
iMac Intel 17"
iMac Intel 20" EMC 2105 and 2118
iMac Intel 20" EMC 2133 and 2210
iMac Intel 20" EMC 2266
iMac Intel 21.5" EMC 2308
iMac Intel 21.5" EMC 2389
iMac Intel 24" EMC 2111
iMac Intel 27"
Compatibility
| iMac G5 17" Model A1058 |
| iMac G5 17" Model A1144 |
| iMac G5 20" Model A1076 |
| iMac G5 20" Model A1145 |
| iMac Intel 17" |
| iMac Intel 20" EMC 2105 and 2118 |
| iMac Intel 20" EMC 2133 and 2210 |
| iMac Intel 20" EMC 2266 |
| iMac Intel 24" EMC 2111 |
| iMac Intel 24" EMC 2134 and 2211 |
| iMac Intel 24" EMC 2267 |
| Power Mac G5 |
Stories
My Problem
My original Hard Drive (250 GB) was showing signs it would soon crash and die forever.
My Fix
Changing out hard drives was pretty quick and easy, especially since I ordered all of the correct tools... it's all about the tools!
My Advice
Go slow, watch the video to aid with the step-by-step directions (but don't rely solely on the video), and be ready to ask for help when disconnecting the LCD screen.
My Problem
original HD failed and took machine with it!
My Fix
Really well - excellent guide and step by step process was painless
My Advice
Lining up the case before fitting the screen back was crucial and took a few attempts - otherwise you think you're home and dry and the memory door refuses to fit back on!
My Problem
I started to have trouble with my iMac and called up Apple to help me troubleshoot what was going wrong. Turned out that my internal harddrive was on its way to completely failing! They told me to back up what I could and turn it into one of the Apple stores or a certified repair shop to have them replace the drive for me, and since my AppleCare was up on it there would be a charge for the new drive, installation and the transferring of all my datta from the old one.
My Fix
I was not about to pay a minimum of $300 to have another 320gb drive installed for me so I came to iFixIt.com and found all the info I needed to create enough confidence to believe I could do it my self at a fraction of the cost I would be charged to have it done. Not only that, but I would be upgrading from the original 320GB to a 2TB internal drive! I received my replacement drive and quickly started to get down to the nitty gritty job. The instructions provided by iFixIt were precise and easy to follow. After only 30 minutes I had pulled the old drive out and the new one in! Since I run TimeMachine back-ups on all my computers, I simply restarted my iMac using the system installation disc, used the disc utility to properly format the drive, installed the system software and restored all my info from my most recent back-up and 2.5 hours later everything was back to normal!
My Advice
The only thing I can advise is to get one of the iFixit screw driver sets. I didn't and went to my local hardware store to pick up the star torque drivers I needed. When I told them what I was looking for they handed me a really nice set that was made for working on computers. I turned it over and immediately recognized the logo on the set.... It said iFixIt! The set worked great and made the job easy. I recommend buying the tool kit along with any other recommended things necessary to complete the job you are going to tackle. Having the right tools makes a huge difference in how the job goes. iFixIt will send you exactly what you need to make the job as easy as it can possibly be.
My Problem
the original harddisk died
My Fix
The repair went just as smooth as you showed on your site. Your guides are really good and i wouldn't been able to do it without y'all. Keep up the good work.
My Advice
Just follow the guide, be careful and you'll be alright
My Problem
A friend contacted me after their computer sat for a year. They asked if I would look at it for them and get it working again. I found a dead HD in the machine and ordered a new one. They went from 250 GB to 2 TB on their machine.
My Fix
The repair was pretty easy. The hardest part was getting all of the EMI tape to lift off the screen.
My Advice
Be careful when taking the EMI tape off. If it has been on for a long time it will tear.
My Problem
The computer was knocked off a table, killing the had drive (and denting the floor)
My Fix
The replacement guide was excellent, and the repair took less time than I expected. The only awkward thing was putting together those tiny wire connectors
My Advice
My wife is much happier with the 2TB drive (vs. 500 GB)
