0
Score
Avatar
joindc
Asked
Home button not working after display assembly replacement
History
I had a cracked screen so I replaced my iphone 4 lcd/digitizer front assembly and home button using ifixit parts and guide. I replaced the home button because I decided to put on a white front assembly rather than black (and thus got a home button to match). I followed the guide and everything works great EXCEPT for the home button. It doesn't work at all! I took the phone apart again to make sure there wasn't anything weird going on w/ the home button or home button ribbon cable and everything looked fine. It does seem like the home button sits deeper (further recessed from the front panel) than the original. Am I missing something? Is there a common issue with this that I should check for?
Post Answer
0
Score
Avatar
Sam
Answered
PermalinkHistory
I would also like to hear an answer to this???
0
Score
Avatar
Craig
603
Answered
PermalinkHistory
Sounds like you knocked the metal contact patchoff the back of the home button flex cable which would cause it to sit lower and not work.
0
Score
Avatar
hammershaug
Answered
PermalinkHistory
Same thing happend here right now, but on a 4S, and first time I encounter this problem. I suspect the home button that was included with the lcd/digitizer front assembly is the problem. First time I make use of it, because I usually move over the complete home button assembly from the damaged display, without replacing the button.
It seems like a good idea to move over the metal insert on the back of the home button... I did not. $!@!, have to start over again.
Add Your Answer
