2.3L 4cyl or 3.0L V6, 6th Generation
426 Questions View all
2001 honda accord has a code p0172
my 2001 honda accord engine light is on. A mechanic suggested a tune up. the car was not shifting gears properly.I thought it was the transmission.i replaced the spark plugs the wires the rotor and distributor cap,and added a can of seafoam.car still does not shift corrrectly.transmission fluid is clean and no burn smell.light is still on so i took it to auto part store and they gave me the codes p0170,and p0172 which means fuel system to rich!ok so know what do i do any suggestions or answers will be greatly appreciated
1 Comment
Same issue here changed fuel pressure regulator, same codes came back, but now is shifting fine after I replaced the knock sensor, but still dealing with p0170 p0172, im checking fuel injectors next.
by
Add a comment
1 Answer
Most Helpful Answer
shawn, of course you are absolutely right about your code:
P0172 HONDA - Fuel System Too Rich Bank 1
Possible causes
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Faulty Mass Air Flow (MAF) sensor
Check your possible causes. I would start with the fuel pressure regulator. There was an issue with moisture in the fuel pressure regulator which habitually used to cause this problem. Recommendations at the time were to replace the fuel pressure regulator, and reroute the fuel pressure regulator vacuum line.There is a technical bulletin about it. Your Honda mechanic should have access to that. If not, I think I can still get it through Alldata, just let me know if you can not get it from your garage. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
shawn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 10,871
